warped rotors
Frozen Rotors front and stock turned rear discs and stock pads all the way around took care of my problems. Cross drilled rotors were a waste of money. Believe the engineers and not the marketeers.
Re: warped rotors
warped within 6 months, so I tend to disagree
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
Maybe the Frozen Rotor people know their stuff better, being from Minnesota and all instead of California.
http://www.subaru-svx.net/forum/show...t=warped+rotor
Check this out, you should be able to take the warp OUT if you follow this thread....
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
FREEZE this!
The latest in my WARPED BRAKE journey:
Two nites ago, I was coming home and the warpage I've been talking about seemed worser (that's right! WORSER!). It actually seemed like something broke, since there was a distinct rattling sound then when I braked. I felt I needed to check this out for safety reasons, so I took the wheels off, inspected the pads and rotors >> Nothing obviously wrong (?)! Some of you know I had purchased caliper pins, thinking they could be one of the very few causes of this continual warping of rotors. I didn't take the time to install them when (about two months ago) I put my last turned (cross-drilled) rotors back on (because the stock rotors had warped) because the pad wear seemed even (apparently no stuck or sticky caliper pin). So, Thursday nite (11pm to 2am) I diddled around hoping to find some obvious malfunction or break (thought a pad may have partially delaminated?), but only noticed a mild to moderate movement in the floating part of the caliper. IS IT NORMAL FOR THE FLOATING SECTION TO WIGGLE (IN THE CALIPER PIN "SLOP") FOR ABOUT 1/16"+ MOVEMENT WHEN GRABBED AND TORQUED BACK AND FORTH? I replaced the caliper pins which I had purchased some time ago, but realized in doing so that the AREA OF WEAR IS ON THE CALIPER BODY, NOT THE PINS!!! Because of this fact, installing the new pins would not eliminate the "slop", BUT SURPRISINGLY SEEMED TO IMPROVE THE WARP SHIMMY (?)! SOOOOOOOOOooooooooo!, again: IS THE FLOATING PART OF THE CALIPER SUPPOSED TO BE FAIRLY RIGID (VERY LITTLE MOVEMENT IF TWISTED BACK AND FORTH) >> IF SO, THEN I SHOULD REPLACE THE CALIPERS (OR AT LEAST THE CALIPER BODIES) WHERE THIS WEAR IS EVIDENTLY TAKING PLACE! This might explain the unexplainable continual warpage of rotors. PLEASE LET ME KNOW, Thanks! ![]() ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() Last edited by James Scott; 05-15-2004 at 11:05 AM. |
State of play.
There should not be any wobble between the two halfs. They should just slide in and out smoothly. Any play in other directions, can cause the pad to chatter on the disk. This could feel like warped disks.
I haven't had the calipers off, but isn't the holes in the ridged half got replaceable screw in bushes? Harvey. ![]()
NO WOBBLE ????????
Harvey: NO! The pins are replaceable, but the "sleeves" in the caliper body that they (the guide pin and the lock pin sleeve) slide in are NOT REPLACEABLE. [One is just a hole in the caliper casting. The other is a permanent sleeve (for the guide pin) which comes as part of the caliper body.] From Subaruparts.com, they only sell the entire caliper (for $221 each).
Wish they were cheaper or the caliper body only was available. I'm anxious to try replacing them! THANKS for your help! ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() Last edited by James Scott; 05-16-2004 at 04:58 AM. |
You can get rebuilt calipers from autozone for around $60. You can check their website. I am using one now and have had no problems with it. They also come with a lifetime guarantee.
Tom |
REMAN calipers
THANKS! I ordered a driver's side reman caliper at a local Autozone store >> Unfortunately, they didn't have the right side caliper (?)
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
Jim,
They should be able to get it for you in a few days if it is not in stock. They had two different brands available. I bought the Fenco or maybe it was Fernco. Tom |
CALIPERS
Tom: I installed the one reman (Fenco) caliper last nite >> Didn't notice any difference, unfortunately! I thought I might try a new one (about $120). The new one may have the tight guide/lock pin tolerances that could make the difference (?).
I'LL LET YOU KNOW . . . . . . . . . . . . . . . . . . . ![]()
