Old 08-08-2003, 07:45 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Send a message via AIM to SVX10 Send a message via Yahoo to SVX10
For anybody with the service manual
Can somebody with the service manual post a ball joint how to? If anybody just knows off the top of their head, feel free to post also. Will I need any special tools (puller?)? Thanks in advance.
-Mat
Time for my very own long list of mods:
92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler
I don't care if Subaru says it's STI...it will always be STi to me
Old 08-08-2003, 10:53 AM
svx_commuter's Avatar
Do you really have a bad ball joint?
I did mine when I changed the front axles some time ago. I think it is very easy to change on the SVX.
Jack up the front of the car and support with JACK stands, remove the tire, remove the lower cross bolt that locks the ball joint to the lower part of wheel hub, soak area with PB Blaster or equal, oh wait soak the cross bolt, heck soak all the bolts, you may have to beat on the lower arm to the ball joint to get it out, only then would you remove the 3 bolts that hold it to the lower arm, A screw driver could be used to pry open the slot in the hub that holds the BJ after the cross bolt is removed, that is why you want both wheels off the ground incase you ned ot turn the wheels to get to the slot. You may need new cross bolts or other bolts depending on corrosion condition. It won't change the wheel alignment much but get it checked. You will have to push the lower control arm down and hold it down, the rubber bushings hold it up.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-08-2003, 03:19 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Never, never, NEVER abbreviate balljoint! Please!
Randy Johnson
Mike Davis -- at Reading VI
Old 08-11-2003, 05:17 AM
SVX10's Avatar
Not sure if the joint is bad...still haven't had time to test it myself. The shop that replaced my CV boot said the ball joint had play in it. I remembered somebody saying it was fairly easy to replace, so I figured I'd do it myself. Thanks for the info!
Old 08-11-2003, 05:58 AM
The best way to test is to jack-up car, support it with stand, remove tire. Then with a pry bar, pry the lower arm away from the steering knuckle. If there is any play, this will show it up. The bushings in the lower arm will tend to keep the lower arm up and with the pry bar used to seperate the joint, the lower arm is pushed down.
Did I say BJ that time?
