can you help with my bucking ? ? ?
In warm / hot weather when I am doing slow turns I get a noise .....and the SVX bucks ....and.... clicks during the bucking as I am turning.
Is this AWD transmission ? ......differential ?? What should I do ? ---aside from trying not to turn ! ! ha ha (I wish it was only my imagination) |
seems like diff but could be a ton of other things as well.
L
Is it binding as if the tranny was forcing 50/50 distribution or does it feel more like something in the steering system?
it could be something as simple as a cv axle..
-adam |
bucking
Does the power light (96's still had them right?) show that it has a trouble code in it? It'll blink like 15 times when you start the car rather than just coming on for a few seconds.
Re: can you help with my bucking ? ? ?
A 96 probably won't have either a campaign filter or a clogged stock cooler, so your Duty Solenoid "C" is probably failing. Most times it won't throw a code. Only the wrongful engagement of the AWD. Doug
Stick the FWD fuse in the fuse box to disconnect the AWD system. If the trouble goes away it is the C solenoid, If it does not, it's some thing else.
Harvey. ![]()
Have you changed the fluid. Mine started to bind when turning at parking lot speeds shortly after I bought it. changing the fluid stopped the binding. I now change the fluid every 10'000 miles. the clicking could be a bad cv joint.
Just a minor aside...
If the FWD fuse is in, but the FWD light does not light up on the dash, it's probably the Duty Solenoid C as well. But in this scenario, the TCU should have registered the problem, and you should see a blinky Power light. VK Quote:
If it failed electrically the TCU will post a code. I have opened up a mechanically failed C solenoid and found that the return spring that returns the armature has broken up, jamming the armature from opening fully, thus applying pressure to the clutch. Harvey. ![]()
