Old 12-22-2009, 06:34 PM
Jeff Jeff is offline
ABS light staying on and running
so i was sitting in a drive through and my ABS light came on. i shut the car off and restarted it. the light came back on. so i drove home and parked the car. i heard a weird sound and opened the hood and there is a sound coming from the ABS system under the hood. any ideas at all what is going on
Old 12-22-2009, 07:17 PM
Blacky Blacky is online now
Re: ABS light staying on and running
The relay is stuck, tap the top of the black box marked ABS. If you want a more permanent fix, remove the screw and you'll see 2 relays. Replace the one making the noise.
Old 12-22-2009, 07:28 PM
thanks a lot that worked!!!!!
Old 12-22-2009, 09:47 PM
Glad I could help.
Old 01-20-2010, 10:18 AM
knight'sSVX knight'sSVX is offline
This happened to me yesterday, and first thing I checked was the relay, found which one was making the noise then took it out. Unfortunately autozone near me does not carry them. So I drove around without the relay to and from the parst store, then when I got home I reinserted the old relay and it stopped buzzing and the ABS light did not come on when I restarted it. I'm hoping it's just a fluke and not gonna come back. But jus in case I'll prob order another relay.
I found this link accidentally, and Hope someone will find it useful, it has the updated modified relay part number. (see below, copied and paste version)
http://svx-iw.com/svxiw/article/print.php?article=16
____________________________________
ABS Relay Sticking
Author: Subaru
NUMBER: 06-28-96
DATE: 06-11-96
APPLICABILITY: LEGACY, IMPREZA AND SVX EQUIPPED WITH ABS BRAKES
SUBJECT:
ABS RELAY STICKING
Should you encounter the following condition(s) please follow the trouble shooting chart as shown.
The ABS Hydraulic Unit Motor continues to run and/or buzz when the ignition key is turned to the off position.
The ABS warning light comes on and a trouble code "52" for a faulty hydraulic motor and/or motor relay is stored in memory.
Note: It is possible for this condition to occur intermittently. Under these conditions the symptoms may not always be duplicated.
Troubleshooting Steps:
Check if the ABS Hydraulic Unit Motor is running or if you can duplicate the condition.
If the Hydraulic Unit Motor is running, does it continue to run with the key in the off position?
Confirm the trouble code, if any, and trouble shoot according to the Diagnostic Chart in the corresponding Service Manual.
Replace the ABS Hydraulic Unit Motor Relay with a modified one. The new part number is 26735AA012. The new relay can be identified by a white line under the word Japan on the relay case.
Note: Always check the part number supersession for any changes.
If the wiring harness is at fault repair and/or replace as necessary.
The new ABS Motor Relay has been changed in production begining with the following VIN's.
Legacy (SIA built): Sedan: T*206647
S/W: T*308128
O/B: T*374098
SVX: T*100004
Impreza: Sedan: T*510065
S/W: T*810189
Coupe: T*410116
___________________________________________
92 LS liquid silver ---> pics here:http://s36.photobucket.com/albums/e8...VX%20LS%20AWD/
Old 01-20-2010, 10:55 AM
Wikedjuggalo's Avatar
Rebuilding
Glad you were able to fix it but you should replace the relay as it will do to again
Old 01-21-2010, 05:18 AM
I'm ordering one from subaruparts, I was looking online last night so far they have the best price , but man it's $40 bucks for a relay
Old 01-21-2010, 08:20 AM
Rebuilding
Possibly get the relay from somewhere else?
Old 01-21-2010, 08:41 AM
Thanks, checked fleabay last night too, No luck...and one online autoparts store wants $56 bucks for it.
will keep looking....
Gamesy's Avatar
Gamesy Gamesy is offline
I have a bunch laying around
I bought one on ebay for like $15 then i happened to find a 93 legacy and their Fuse box is nearly identical to ours. so I looted it all for the fuses and relays
I can send you one if you want. I got quite a few kicken around
Old 01-21-2010, 08:54 AM
That would be great, pm me how much and if you have paypal. Thanks.
Edit...maybe i should post a pic of the relay I need first? cause there's 2 of them underneath the ABS motor cover.
Also did'nt realize ur in Canada, hopefully our relays should be same?
Old 01-21-2010, 09:27 AM
Gamesy's Avatar
ya sure send me a pic. I have Denso Ones so if you have the same can always match up the numbers on em.
pm me your address and i'll get a
price quote and i'll give you a price based on the shipping.
Old 01-21-2010, 09:51 AM
PM sent. thanks!
Old 01-21-2010, 10:39 AM
Oddly, I dont think you two are talking about the same relays. The relay for the ABS which is faulty is under the black plastic cover on the ABS Unit and not in the fusebox. There is a Bosch replacement relay if I recall correctly. I may have just used another OE one that I had from the '97 parts car I had.
Old 01-21-2010, 10:43 AM
that is the one I pulled out. there are 2 relays under the ABS (black plastic ) cover. One of them was faulty and when i removed it the noise stopped.
edit: this is the info on the old relay: 112 000 10050 Nippon ABS ltd. japan 10318
