Old 05-22-2007, 10:12 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Originally Posted by Nomake Wan
My dad's explanation for turns and rolling stops is fluid shift within the torque converter. It sounds... well, sound.
I can put more fluid in to get the car somewhere, right?
Depends how fast it's leaking??
Many times, the problem will be at the end of the hose. Check the clamp (8mm socket), if it's tight, pull the hose and remove 3/4 - 1" and reconnect and clamp it.
Old 05-23-2007, 05:39 AM
dcarrb dcarrb is offline
No expert here, but I'm pretty sure low ATF could cause the sort of hesitation you've described. And yes, if the fluid's getting onto a hot surface, it would smoke (tho' this wouldn't explain it coming literally from behind the timing belt cover; maybe it's actually coming from the exhaust header). Whatever; you really should fix that leak before going far. If that's truly all that's wrong it sure would be a shame to burn-up the tranny for want of a new clamp or length of hose, both of which are cheap and can be bought anyplace.
dcb
Old 05-23-2007, 04:42 PM
Trevor's Avatar
Trevor Trevor is offline
Fluid level is fine, no loss there. Nice cherry red color too. Front diff fluid is also nominal (I was there, figured I'd check it anyway).
I would presume all of this to be correct.
Trevor, New Zealand.
Old 05-23-2007, 04:54 PM
Nomake Wan's Avatar
Nomake Wan Nomake Wan is offline
Retired
Send a message via AIM to Nomake Wan Send a message via MSN to Nomake Wan Send a message via Yahoo to Nomake Wan Send a message via Skype™ to Nomake Wan
It was, to the best of my ability. When I tested it in the morning after running it the dipstick looked like it was on the F reading. Could've been my mistake. Probably was my mistake, considering all the ATF all over my driveway.
Old 05-26-2007, 01:28 PM
Nomake Wan's Avatar
Retired
Fixed the hose, no more leak from the radiator, no more ATF in my driveway. On the other hand, I'm leaking something else. Looks like it's just water, but after the recent events I'm kinda paranoid... here's a pic. I just put the camera under the leak and snapped a shot, so...
Wonder what the black tube in that pic is, it looks wet... Hopefully I'm just being paranoid and it's just wet from the rain we had last night...
Old 05-26-2007, 02:29 PM
n00b on demand's Avatar
im pretty sure that dusty/wet tube is for the a/c....water comes out of there
Old 05-26-2007, 07:14 PM
Nomake Wan's Avatar
Retired
Yeah, I'd been using the A/C today and my parents were like, "Yeah, your old Legacy used to leave puddles of water on humid days like this too." Good to know.
Thanks for all your help, guys! Case closed!
