Old 03-20-2006, 07:34 AM
zavikan zavikan is offline
Send a message via AIM to zavikan
A few annoying problems I want to fix:
My trip meter does not work apparently. Odo works fine. The button for the trip meter feels "funny". The car used to have white gauges that I removed. I dont remember if they worked before that. Suggestions to fix? Can I replace just the trip meter? I have a donor car.
The car has Drilled/Slotted rotors all the way around. Under hard breaking I notice a low "wwssshhhh" sound, for lack of a better term. There doesnt seem to be any warping. Pads are fine. No squeel. Is this the nature of this kind of rotor?
There is rust forming on both sides behind the rear wheel. Isn't there some drainage tube that gets clogged and causes this or something?
I had more questions...but I forgot them... I'll be back with them later..
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 03-20-2006, 08:15 AM
Try "Flicking" the trip button, and holding it in, then letting it "flip" back out by slipping your fingernail off it to th eside...got mine to start working again on my old pearly that way.
I don't have slotted and drilled rotors, so I'll hold off on any comments on that...
As for the rust, you just have to make sure you spray back up around th einside of the wheel well, to rinse out all the grime and road salt that can build up in there....a automatic car wash will NOT clean this out.
But if there is already rust there, there's no avoiding it now, and body work will be needed to stop it.
Old 03-20-2006, 08:18 AM
I also have this EXTREMELY ANNOYING whistle when ever I use my Heater in the car. any speed. Though its volume changes w/ the speed (low med high)
Suggestions to fix? its so annoying...
Old 03-20-2006, 08:23 AM
Pull the heater motor out and oil it....it's kind of behind the glovebox..
Old 03-20-2006, 05:30 PM
Earthworm's Avatar
Meow!
Actually the motor can be oiled without removal. The bottom cover is held on with 2 screws. Remove the cover, clean out all the junk, put a few drops of oil in the cover (there's a gauze in the cap that holds it) then replace the cover.
The brushes eventually wore out on mine and I had someone cut new brushes to fit. Working great ever since.
Old 03-20-2006, 07:59 PM
...Ok. could you better describe the motor location?
Flicking the Trip didnt work.
Old 03-20-2006, 09:49 PM
19svx94 19svx94 is offline
Send a message via AIM to 19svx94
all slotted rotors whistle when coming to a stop its just the heat pockets in the slots being built up and releasing
Old 03-21-2006, 02:30 AM
Speedklix's Avatar
Locker Link Solution
yup, its normal.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-21-2006, 11:41 AM
Earthworm's Avatar
Meow!
Look up from where the passenger's right foot would normally be. The bottom of the motor is held on with 2 screws. Be careful when removing it as there will be a lot of junk in there. I've done this on 2 SVX's now and both were packed pretty good.
Old 03-26-2006, 01:20 AM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
will try this today....
-Pavan
Old 03-26-2006, 05:18 AM
hmmm. I tried prying it away, and it won't come off. How hard is it supposed to be?
James
Old 03-26-2006, 08:52 AM
It's Just Eric's Avatar
Missing in action
I have all the problems you listed except the rusy one.
my trip meter, I just drive and jiggle and mess around with the knob for it untill it actually starts working
The air conditioning whistle...I think is probly a misaligned duct thats leaking (and whistling at the same time )
The drilled and slotted rotors are suposed to make that funny noise
R.I.P Cool Signature.
Old 03-26-2006, 12:37 PM
pavanbabut's Avatar
Thumbs up
Yep, having some oil drops in the container hole stopped the whistling noise.
Here are some pics in my locker
thanks earthworm and huck, I am thinking of replacing my motor before this small repair.
-Pavan
Old 03-26-2006, 12:41 PM
immortal_suby's Avatar
Thread Killah
-Pavan
great pictures - I think I'll go do this now - my motor has always been loud but I always figured it was just the noise of the air in the vents.
Locker Link
2015 BRZ Limited 6MT
Old 03-26-2006, 12:48 PM
pavanbabut's Avatar
Hi,
our vents are loud when you are running them at high speed, thts just the noise of air I beleive. The noise we are talking about is the whistling noise which you can clearly hear from under the passenger locker area and the pitch changes according to the speed you select. I am not sure if you are talking about this noise or the vent noise but just want to be sure about the type of noise.
good luck,
-Pavan
