Old 03-23-2005, 09:23 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Question abs has gone loco!!
when i'm coming to a stop and get to about 2 or 3 mph my left front brake pulses till i stop. it also seems to kick my already suffering tranny into neutral while it's happening and i can't imagine it being good for it. (it already has a bad line pressure solenoid) it happens probally 98% of the time and it really sucks. i pulled the fuse for the abs solenoid so it's all good for now, but i'd like to fix it. any advice would be good. how hard is it to replace the solenoid in the tranny?? need to know so i can decide whether to deal with it myself or not.thanx
Old 03-23-2005, 10:09 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Is your LF tire flat or a different size than the other tires? If the ABS detects that it is turning slower than the other wheels it will begin pulsing that brake.
Old 03-23-2005, 10:16 PM
Budfreak's Avatar
Banned
no. all the tires and such are new. i check the pressure all the time too.
Old 03-24-2005, 11:15 AM
Earthworm's Avatar
Meow!
It doesn't pulse while braking at higher speeds? If it was I would have thought maybe the tone wheel.
Old 03-24-2005, 12:27 PM
Beav's Avatar
Not as old as Randy
It may be a wheel speed sensor going south, not generating a pulse at slower speeds. Check your ABS codes to see if it shows an error. After that the only good test is with a graphing meter.
Old 03-24-2005, 12:32 PM
red95svx
Agreed. A failing sensor (or even one that is just dirty) can cause ABS activation at low speeds. My 92 had the same symptoms. Sometimes it threw an ABS code, sometimes not. A new wheel sensor cured the problem.
Old 03-28-2005, 09:20 PM
Budfreak's Avatar
Banned
the abs isn't throwing a code and yes, it only happens at about 3 mph and under
Old 03-29-2005, 04:12 PM
oab_au oab_au is offline
Its a magnetic pick up and its output depends on the speed that the tone wheel passes it. As the magnet weakens, with age, the output at lower speeds is too weak, So the ABS thinks its stopped, (wheel locked up). As the speed is increased the signal becomes stronger, to work ok.
Just need to find which one.
One Arm Bloke.
Tell it like it is!
Old 04-06-2005, 08:24 AM
Budfreak's Avatar
Banned
Smile
thanks for the help guys. that makes sense to me about the pickup in the wheel. i'll check that out when i get a chance and let you know what comes of it.
Old 04-07-2005, 02:11 PM
angrydan angrydan is offline
My SVX did this right after I got it. I actually never got around to fixing it, I just pulled the fuse for the ABS. My ABS doesn't work, but I have yet to be in a situation where i've needed it. At least it stopped the brakes from going nuts every time I stopped!
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
