Old 01-24-2005, 01:31 AM
The Molinator
Headlight HARNESSES...
I had SilverStar bulbs in my lowbeam headlights for about one year...before (prematurely) burning out.....I replaced the burned out SilverStars with the original bulbs that I saved...which work to this day! [about another year later!].........I recently was told that the premature failure may have been due to inadequate harness wire size (?).........Also, the quality.... or more appropriately.....intensity of the SilverStars was not noticeably better than the stock bulbs! I was told this ALSO may be a result of the inadequate stock harness wiring (?)....
I remember reading something about a headlight harness mod....possibly for this application... Let me know what you think ....and whether or not this belongs here ...or in MODS site(?)
THANKS for your help!
Jim
Old 01-24-2005, 08:46 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Do I want to get into this discussion again?
Uh... when you run a higher wattage bulb, you'll need a thicker set of wires. Otherwise, the wires heat up and melt. If you have the same wattage, and if the blubs fail, it's just crappy bulbs.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-24-2005, 09:25 AM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
I upgraded my wires. I got the kit from ebay for about $30.
Just get the one for 9005 9006. I think napa allso can get them.
The one I got is made by Matix
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 01-24-2005, 03:33 PM
Green1995SVX
Your best option would be to run some fused/relayed power from the battery directly to the headlamps using a lower gauge gauge wire and a heavy-duty connector.
Mike
Old 01-24-2005, 10:48 PM
The Molinator
GAUGE this....
SOOOOOOooooooo......
LWIN...... Are the Silver Stars higher wattage than stock bulbs ?.....How much difference (in wattage) is enough to require "thicker" wire (harnesses) ?......
MIKE...... How could the higher wattage bulbs require a "SMALLER GAUGE WIRE" ?
If I'm treading on previous ground, gentlemen, please refer me to the old threads......Otherwise, please expand your comments to include the best possible approach to switching from stock bulbs ...to these SilverStar bulbs, which are so popular...
THANKS for your time...and wisdom...
P.S. So is it true that the stock harness with these SilverStar bulbs .....would be likely to shine DIM and FAIL PREMATURELY ?
Jim
Old 01-24-2005, 10:54 PM
The Molinator
Lower....NOT ....thinner
MIKE....I see my error...You said lower gauge (THICKER)....not smaller gauge!
SORRY....
Jim
Old 01-25-2005, 09:39 AM
AFBeefcake's Avatar
Subaru Swapper
The one I got looks like this one, but its for 9005/9005.
you can get them here for $29.99
http://www.jegs.com/cgi-bin/ncommerc...10&prmenbr=361
2005 Legacy GT
Old 01-25-2005, 10:33 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Huh?
Now I know why I see just fine with stock.
Lee
SVXx5
Old 01-25-2005, 07:46 PM
The Molinator
harness
I ordered today 9005/9006 harness from Jeg's
THANKS
Jim
