Old 05-11-2003, 05:24 PM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
fwd/awd fuse
While checking my a/c fuse, I noticed the fwd fuse was missing. I know this is OK because it should only be used in emergencies. However, the whole area looked fried. There were no prongs there to hold the fuse. I want this option in case the car ever has to be towed or I need FWD in some emergency. How do I repair/replace this fuse holder?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 05-11-2003, 05:37 PM
lee lee is offline
I have a partial answer - but admittedly not a good one. On my car the same thing was true as well as the A/C relay plugs were loose. What appears to have happened is the whole block in front of the main fuse block cracked, but I didn't know that until I started checking it out. I was able to push the block out of the holder through the bottom and open the block of contacts up. I used some silicon adhesive/caulk to hold the contacts in place, then put the assembly back into the holder.
For me the only right solution would be to acquire a whole new block and associated wiring. My way works but not very elegant.
hope this helps, or somebody else chimes in.
Old 05-11-2003, 06:51 PM
Earthworm's Avatar
Meow!
The slot for the FWD fuse has grease in it. It will be very discolored over time. Put a fuse in there and see if the FWD light comes on on your dash when you start it.
Old 05-11-2003, 08:37 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
also, it won't help for towing
you'll still fry the diff if you try 2 wheel towing it when you have it in...
SV What?
Old 05-11-2003, 08:51 PM
Green1995SVX
there is a non-conductive greese in there. This is used, i would imagine, to prevent something from falling in the slot and connecting the terminals.
Mike
Old 05-12-2003, 06:29 AM
RSVX RSVX is offline
Network Design Administrator
I too thought mine looked fried at one point, then Earthworm here guided me in the correct direction, it was grease just very very dirty grease
Life is a game. Play to win.
Old 05-12-2003, 08:28 AM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Where exactly is the FWD fuse located at??? I've never really cared to take mine out of AWD..... But now that everyone is talking about thier block being fried I think that I will check mine to see if mine is messed up too... So where do I look????
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 05-12-2003, 08:49 AM
fuse box under the hood, the fuse location is clearly labled, unless of course your fuse box label is gone.
Old 05-12-2003, 11:14 AM
Oh, cool... I've never had to look in the fuse box before..... Guess since I see my car so very little I just don't know all that much about that part of it....
