Old 04-10-2003, 07:29 PM
Roger8519 Roger8519 is offline
Angry shaking
Hey,
I have had this problem lately. Anytime I go around 60 mph lately been doing it around 50, the steering wheel shakes very badly. What is wrong?
Roger
Old 04-10-2003, 07:55 PM
mbtoloczko's Avatar
sans SVX
Re: shaking
Originally posted by Roger8519
Hey,
Roger
Any number of things:
thrown wheel weights
misalignment
worn suspension
bad driveshaft
bad CV joints
and probably more
Mychailo
Visit my locker
Old 04-10-2003, 11:59 PM
SHISVX SHISVX is offline
i had that problem in an old car of mine...tie rods?
Kelli
Previous owner of the
Princess Pearlie "Dimples"
as of 8/6/03
1992 LS-L Pearl 124k
"Yeah, that thingy!"
owner of the new 1992 LS-L Pearl "Susie"
I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy.
Old 04-11-2003, 08:49 AM
svx_commuter's Avatar
Bad Tires Too
Sart with the balance and a check for loose components. To check the axle CV joints, dirve in a tight circle, and lightly hit the gas. Listen for poping, cracking noises. If everything checks out and you still have the problem it's the tires.
Old 04-11-2003, 10:05 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
more often then not this is cuased by not spin balanceing the tires, Get them remounted and balanced, see if that helps
phil
~Phil
