OK, back to square one. A few months ago I had to pull a power supply from my desktop machine to keep the SVX server going. We were even lucky enough to have a member ( I think it was zsvx ) send up a spare 400 watt ATX power supply. Unfortunatly it was DOA. I got used to using my laptop in place of my desktop machine but we have now come to another problem. Either the battery in my IBM Thinkpad has all the sudden chosen to fail, or the motherboard charging circuits have failed. Anyway I look at it, my laptop is out of service now AND I am moving. I must move to another county where I have applied to work in law enforcement and I need to get my desktop back in working order.
SHORT VERSION: We need to raise money for a CrapUSA 400watt ATX power supply for $60. So, lets pull together and help me out just a bit. When I get paychecks rolling in again, it wont be so much of an issue. Lets look at a few things. We have well over 30 VERY active members... almost HYPER active. All we need is $2 from 30 people to make this happen. Please post your bid ammounts and when we reach the magic number I will supply paypal infomration. Better than that, I will provide the group with the recipt as well as pictures ![]() ![]() ![]() Thanks for your support Chris (SVX Admin) |
no problem, I'll gladly put in $20 when you put up the paypal info
Where do you want me to send the check to? PM me and I will send you a check for another 20. And let me look around for other parts I have lying around too. I think I might have an 300W powersupply lying around... as well as a few lan cards and modems... If you want, you can have some too.
Lwin
E-mail me your snail mailing address & I'll drop you a $20.00 check pronto. Ron.
Good s**t happened. ![]() '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Looks like the magic number has been achieved. As always, if you need further, let me know. If another 20 will get a better power supply, I can add it.
Thanks Matt, Lwin and Ron. Proof positive that this is OUR network. You guys are great!
Chris,
If you are willing to take a 300W, give me the address and I'll drop one in the mail today. Trust me, even with 5 SCSI HD's the 300W will be sufficient. What models are the HDs anyways (just so I can check the Amp draw)? VK |
8.45 amps !!
Well, its not just the drives. You see there is 4 7200 rpm Barracuda 1/2 height drives in the machine. They run so hot that I have them each in 5.25" bays with drive fans. Then you have the draw of a full size RAID controller with 32 megs memory, 256 megs of ECC system ram, and TWO slot 1 Pentium 3 CPUs. I think the biggest draw is the HDs and all the fans. There is two in each drive bay (in two bays), two on each CPU, and one each on the front and back of the machine. Thats 10 fans! I put my Fluke meter on the 12 volt side and checked for amp draw. 8.45 full time draw and 10.8 peak for start-up. Good thing I have the drives set to stagger spin up. Honestly I have too much hardware in too small of a case and I should replace the older 1/5 height drives with low profile ones that run cooler. Eventually I hope to just buy a 2U rack mount machine and move the SVX board over to a new machine.
So you see, I am running about 80+ percent of a 300 watt. I am thinking that high load and slightly high temperatures killed the last one. I am hoping that a 400 watt will run cooler and with less than 80 percent load, last longer. Thanks for the offer vkykam! Chris (SVX Admin) |
Paypal info
For those of you who genrously bid money to help keep SVX-World Network going, THANKS. Once I get a job again and get caught up on stacked up bills, I will rebuild the machine a bit better, rack mount, and with redundant power supplys!
I prefer to do this through Paypal. It makes it really easy as well as MUCH faster. Paypal information is: c_town@hotmail.com or if you choose the good ole postal service, send check or money order to: Chris Townsend 5921 South Tulip Place Boise, ID 83716 Once the project is done, I will post pictures of the power supply, recipt, and the install ![]() ![]() ![]() OK.. Thanks again for all the support. I promise I will make more apperances once my life starts to settle down a bit. Chris (SVX Admin) |
Re: Paypal info
Good luck on your new endeavor. Don't forget to put another liner in the can after you take out the trash -- my son ALWAYS forgets. ![]()
Re: Paypal info
Amusing isn't it how in Ideeho, a right to work state, all the employers seem to think that the people that work for them should be able to live on 6 bucks an hour. I negotiated one job up to 10 bucks, and they only called back later, (after I had accepted the job), to tell me that they found someone willing to work for less money. ![]()
Pull my finger! |
i will enter the $20 club.....
tell me when and the money is in the mail. i love this place.....i would say it is my home away from home.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Re: Re: Paypal info
Re: 8.45 amps !!
Most 300W PS have between a 12A and 15A rating on the +12V, so it *should* be sufficient.
The problem is, most power supplies that come with cases on the market, and most power supplies from not-so-reputable manufacturers are overrated. It's a pretty common (and shady) practice to have a manufactuer slap on a 300W rating on a 230W or 250W power supply. So if you decide to get a CrapUSA (as you would put it), just be careful of what you are buying. Or, someone chip in $20, I'll cover the rest, and I can get you a Enermax power supply, 350W, with dual fans (yes, more fans, that's what you need!). Or $40 for the 431W model. Full specs at http://www.enermax.com.tw/products/switch-main.htm Quote:
Re: Re: Re: Paypal info
As far as consulting on auto repairs, c'mon, I've been in the business for twenty + years, and it's hard enough to get people to buy real repairs. ![]()
Pull my finger! |
Leo or Randy
one of you guys might have to take over my task of sending 20 over to chris. I am going though my funds and i am getting low as well -- esp. with my car not moving -- I have no idea how much I will need to spend on that. Sorry chris. Lwin
