Old 12-21-2020, 05:48 PM
Lsvx-t
Not sure where to put this so what could be more proven than an LS swap. Been blocked from FB because someone tried to hack my account so I'll post some pics here. Making some serious headway but a lot more fun to come
Old 12-26-2020, 10:01 AM
ZoraSVX ZoraSVX is offline
Re: Lsvx-t
Sorry to hear about your FB accounts. Glad to hear you are making headway. This will be really cool when it's done. What did you end up doing for suspension? I recall you were looking for a set of front coilovers... looks like you found a pair?
- Lenny
Current car: 2006 Saab 9-2x Aero, Midnight Black Mica, 180k miles, 5MT, mostly stock
Past car: 1995 Subaru Impreza wagon, EJ20G w/5MT, Koni Yellow inserts/STi wagon (GF) springs, swaybars, and other suspension goodies, STi seats
Future car: SVX, of course!
Old 12-31-2020, 12:39 PM
Re: Lsvx-t
I ended up buying a full set of Geckos as AMR is useless to even try and contact. I took the springs and top mounts and adapted them to my 350z coilovers I am using in the rear so it makes a perfect setup. I sold the rear struts to someone who needed just rear struts so it worked out for both of us. It looks like I will only need to slightly modify a front sump aftermarket oil pan for clearance so that will save time from fabricating a whole oil pan. I have also began gather parts for the engine build which when it is done will run around 7k rpms and hold roughly 900hp which should be more than enough headroom, at least for now. My FB account has been reactivated but its not the same as the forum, so I will continue to update with progress as time goes on. Hoping to have my last driveshaft flange soon so I can get the measurements for the shop to have it made. I am currently bargain hunting for an LS-3 intake manifold and then I will start sourcing my fuel system components for the engine. I have still got to close up the trunk and measure out my fuel cell and get that ordered as well. I don't think I will run the car N/A anymore either as it will just waste energy remaking the cooling system over again to make room for a charge air cooler etc. so I think I will just forge ahead with the turbo kit fab once the engine is done and ready to go in. But even as I write this, I am not totally sold on this either so we will see when it gets closer. For now I am trying to budget my spending on this project a little rather than just burning the cash right away. Will post more when more progress is made
Old 12-31-2020, 05:42 PM
irox irox is offline
Re: Lsvx-t
Thanks for sharing (especially since I don't Facebook). Looks like an awesome project!
I like the targets just left there, a great way to say "Don't touch!".
Happy new year!
Ian.
Old 01-03-2021, 03:01 PM
Smile Re: Lsvx-t
So only a little progress this weekend. I have started to rebuild the trans tunnel prob half a day from being completed. I'm still waiting on some parts to complete my driveshaft measurements. Once I've got that done I can pull my mock up engine and trans so I can disassemble trans and install the new tailshaft housing. I did however get my ball joints installed. Since the sti rack has 14mm inner ends and the taper diameter for the out tie rods was different I had to make something work. I found some gmc work van tie rod ends are the correct length and nearly correct pitch so with a little modification of the spindle they will work well.
More pics when I get a little further
Old 01-04-2021, 04:41 PM
Re: Lsvx-t
Some goodies came in the mail today
Old 04-28-2021, 04:28 PM
Re: Lsvx-t
Updates. Got a little more done although I haven't been able to spend as much time as I would like to on working on it. Pics below
Old 05-02-2021, 04:49 PM
Re: Lsvx-t
Little more progress this week.
Old 05-26-2021, 05:16 PM
Re: Lsvx-t
No pictures to show just yet. I have just about finished up my mock up. Need to finish one more oil cooler line and it's finished in the engine compartment. Once mockup is complete I will be emptying out the engine bay and cleaning and painting.
I still need fuel injectors, plugs, wires, ems, tons of wiring, brakes, and wheels/tires. Things are still moving forward and I still have hopes of the car running before the end of the summer. More pictures soon
Old 05-30-2021, 02:31 PM
Re: Lsvx-t
Now that mock up is just about done. I pulled engine,trans, and subframe along with all supporting goodies to clean everything in the engine compartment and give it a spray. Had to get some paint on the welded bits anyway. More paint, a few more parts and it'll go back together
Old 05-31-2021, 07:12 AM
SVX_MY_BABY's Avatar
Re: Lsvx-t
Holy S**t
Peter
Old 06-12-2021, 06:06 PM
Re: Lsvx-t
Started on the brakes a little. Front lines are done as well as plumbing in the proportioning valve and bulkhead for rears. Definitely will need another roll before I can go any further.
Old 06-13-2021, 07:50 AM
processengr's Avatar
Re: Lsvx-t
Wow Tom! You certainly tackle the tough ones! You should be working in aerospace!
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 06-13-2021, 07:16 PM
Re: Lsvx-t
Gordon glad to hear from you it's been a long time! How are things?
Old 06-29-2021, 05:34 PM
Re: Lsvx-t
Haven't stopped working. Currently brake lines are complete. I am going to start working on the electrical systems soon. I am rewiring the entire car for minimalism. Currently waiting for a big chunk of parts as a lot of it is back ordered. My Holley ems, wilwood brake kits, and some misc switches and cables. Pics once I start putting some of these parts to work
