Old 08-28-2018, 06:24 AM
alia176 alia176 is offline
Send a message via Yahoo to alia176
HVAC code 14 & 15
Hello all,
I'm experiencing the following two codes in the HVAC system, code 14, 15.
14 - evap sensor
15 - refrigerant temp sensor
Even though they check out fine using the manual and a DVM, I might just drop the Evaporator under the dash and replace these two sensors. I also might have a dead mouse in there some where and it's smells. The blower is clean so I'm guessing there's a nest in the evap somewhere, I hope.
I found this diagram and I see two sensors, items #4, #5 but not sure if these are the correct sensors for code 14, 15.
https://www.subaruparts.com/auto-par...omponents-scat
Item 4 is called Overload sensor
Item 5 is called Cooling sensor (discontinued).
Am I on the right track?
Thanks.
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 08-29-2018, 04:32 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: HVAC code 14 & 15
Both still available from Subaru warehouse in Japan - just flick the numbers in top RH corner inquiry -
https://www.amayama.com/en
this is where I get my parts from.........
plus they do other Japanese parts, just select a manufacturer from the list at bottom LHS
Old 08-29-2018, 06:26 PM
Thanks for the info. I tried punching in my VIN and my vehicle didn't come up. Furthermore, I see Alcyone SVX as the only option on that site. How do you navigate this site?
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 08-30-2018, 05:50 PM
SURTEESS's Avatar
I would just punch in the numbers at top RHS, then scrool down to see availability near bottom of page.
Before you can buy anything you need to join - let them know your address and card details (it is safe - I've been using this company for over 15 years).
Old 08-30-2018, 07:59 PM
Ok, I got it now. My parts are available and for not much money, HOLY COW!! let me pull the evap out and do a quick resistance test on these two sensor and see if I find anything else that needs to be replaced.
Thank you.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 08-30-2018, 09:12 PM
SURTEESS's Avatar
Yes the cost is fairly cheap, postage may sting you on smaller items (bit like sending stuff out of the USA).
