Inhibitor switch
Hi everyone:
I have owned my 1992 SVX with 110,000km, since August, 2001. Over 16.5 years of ownership. It hadbeen used regularly for only the first 4 years. 5000km each yr. The last 12.5 years only put on 8000km. Now its 138,000km. Parked most time, used 4000km each time twice during second 4 years. The last 8 years parked most, from now back was parked 1, 3, 1, 1.5, 1.5 years respectively, Each time only driven 3-40km in 2-3 days and parked. Each time it could started in one click. Only the last 2-3 times I have had to start in Neutral. The problem of my inhibitor switch was strange this time, after I parked for 1 year, and 3 years before that. Before it could always started in Neutral, but this time, (and last time that I after I parked for 3 years) after I (first time) started in Neutral and run for 10km, shut it off and start again in Park. OK the first time; second time, its silent in Park. So I put it into Neutral... silent too. I put it back to Park, and it starts in one click. Is this the inhibitor switch problem? Someone said if I use the car frequently, it will come back good, but because I parked it for too long, it forgets its gear position. Any comment? Please, if anyone can show me the link for location of this switch, and how to clean or change it (I suspect it may just be dirty) and /or where can I get a replacement part. JDM model. Thanks .
1992 SVX whitepearl 129,000km 2005 MAZDA3 red 38,000km 2001 HYUNDAI XG V6.3000 2003 TOYOTA PREVIA Last edited by svxcess; 04-07-2018 at 06:29 PM. |
Re: Inhibitor switch
It needs to be driven. Sitting idle is the worst thing for a car. Is it stored indoors?
P.S. Change the oil right away!
But was very clean now,, P.S. After not changing the oil for 7 yrs, I had changed it about 1 year ago After parked for 1 year, I now try to run it every 2-3 days,about 10km each. I will try for this whole April month to see if the inhibitor problem will cease. It seems that same things happened to my 1999 Audi A6 4.2 with 123,000km Parked similarly, it got a gear sensor issue as well, whereas when put in reverse, light comes up and car goes limp. I have to restart and go only forward. But after regular use for the past year, the problem is now solved, even put in reverse, no problem. Hopefully, it’s the same as the SVX .
1992 SVX whitepearl 129,000km 2005 MAZDA3 red 38,000km 2001 HYUNDAI XG V6.3000 2003 TOYOTA PREVIA Last edited by svxcess; 04-07-2018 at 06:37 PM. |
reverse is a manually selected gear ,you could change the fluid and let it warm up
Part no. 31918AA090 It’s for Subaru WRX, 2008 and up. Anyone know if this part no. can be used in SVX? (I asked the Subaru dealer in NZ once years ago) They quoted me 300NZD from Japan. Recon if its only 82NZD. might as well replaced DIY) solved .
1992 SVX whitepearl 129,000km 2005 MAZDA3 red 38,000km 2001 HYUNDAI XG V6.3000 2003 TOYOTA PREVIA Last edited by svxcess; 04-07-2018 at 08:01 PM. |
Tigersvx, you have a private message
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
