Old 12-04-2017, 09:04 AM
THE NEW GUY THE NEW GUY is offline
ABS shaking everytime I press brake pedal since rear wheel bearing change
Hello Guys,
Since I changed my rear wheel bearings some months ago, I noticed my ABS is activating every single time I brake. First the ABS light came on so I added some spacers to reduce the distance between the ABS sensors and the target crown. after that, the ABS light does not come on but I feel the ABS pump is activating each time I brake, right at the point when I release a little the pressure on the brake pedal. During summer, to avoid this anuance, I removed the big fuse of the ABS pump, but now, in winter, with all this ice, I need my ABS back so I replace the fuse and the problem araised again. Do you think one of my ABS sensor was damaged during the bearing replacement process?
Any comment will help.
Thanks.
Old 12-04-2017, 09:17 AM
Re: ABS shaking everytime I press brake pedal since rear wheel bearing change
Originally Posted by THE NEW GUY View Post
Hello Guys,
Thanks.
Yes, Damaged sensor would be my first guess...
Old 12-04-2017, 12:33 PM
Loved your article on the XT's page.
Old 12-04-2017, 12:41 PM
Why thank you
Old 12-05-2017, 06:57 AM
SVX_MY_BABY's Avatar
If you have a lot of rust, the part which looks like cogs on a gear which the sensor looks at, may be corroded to the point that the sensor can't detect the gaps in-between. (don't know it's name)
Peter
Old 12-05-2017, 10:00 AM
I call it "the target crown". And no, there's no rust there. I actually add spacers to make it closer to the sensor and it s better, but still annoying.
Tags
abs, pedal, shaky
