Door cards disintergrating
SVX 95 -117000k
I'm onto my third rebuild of my door cards. The pink plastic moulded stuff is gradually fracturing all over. The inner handle just pulls out. Has anyone come across a permanent fix? I fixed the nacelle under the steering wheel with fibre-glass and gel-coat and it seems to be holding up OK, but I havn't had it off yet;-) I'm thinking this time of coating the whole thing with gel coat, but rebuilding the screw attachments is a long and painstaking job, and I inevitable get 1-2 mounting posts off center! Dont suppose anyone out there has made a fibreglass mould? I guess these days they could be 3D printed? Dont suppose new cards are available? Any suggestions appreciated regards Don McAlpine Otaki New Zealand |
Re: Door cards disintergrating
Pink Plastic door cards?
OK. I Googled "door cards" called door panels in this hemisphere. The rest I simply don't comprehend.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
I have never seen a door card disintegrate, my 92, 95 and the 1 parts car all had decent door cards (except for the dirty arm rests). Are you in very warm climate?
I usually alternate between door cards and door panels (usually I say door cards to mess with older people ). You'd probably need a fairly large 3D printer to print an entire door card/panel, but I've thought about trying to print parts before.
Don,
never had any issues with my cards/panels - maybe your plastic liners are not sealed correctly - letting moisture in ?
