Old 05-26-2015, 03:56 PM
ATF Pan leaks, 96-97 cars
Has anyone here used an earlier-design transmission pan gasket in a transmission pan designed for Fujibond? Have you experienced a leak?
One of our members here with a 1997 started to have an oil leak possibly because he had a dent in the pan. Replaced it with a new one.
He tried using the gray "Fujibond-type" (not OEM) sealant and it did not seal the leak and seemed like it never cured. He removed the pan again and removed the sealant completely (it just wiped off) and used the transmission pan gasket (from an aftermarket SVX ATF filter kit). Still has the leak in the same spot.
Here is what I found out from Subaru Techline Technical Analysis and Performance today.
The redesigned 1997 SVX Transmission Pan, part number is 31390A060 and is designed to be used with Fujibond
The original 1992-1994 SVX Transmission Pan number is 31390AA039 and designed to be used with a pan gasket. The gasket number is 31397AA041
Midway through the 1995 model run, Subaru changed from the old pan/ gasket to new pan/ Fujibond.
The change was not determined by VIN or production date, but by transmission #.
92072 and later transmissions used Fujibond
92071 and earlier transmissionsused the gaskets
All 96 and 97 cars were Fujibond
Subaru also confirmed there are only 2 types of Fujibond in use.
GRAY:
used in engine assembly only. Designed for precision-mating surfaces and high torque fasteners
RED used in transmission pans and oil pans.
The red Fujibond will stay relatively soft and shiny after curing. Do not substitute the gray for the red to prevent leaks.
RED Fujibond K0877YA020 (Also called Subaru Three Bond Sealant)
What has been your experiences? Keep the new pan and use Fujibond or go back to the original pan and use a gasket?
Have any members who have the later Fujibond had leak problems, such as after replacing the ATF screen filter?
Can anyone confirm what the actual pan differences are (profile, cross section..? I believe the later one has a small raised lip around the perimeter to contain the Fujibond, but not sure.
Old 05-26-2015, 05:14 PM
bheinen74 bheinen74 is offline
Re: ATF Pan leaks, 96-97 cars
interesting.
not many of us have 97's
If I ever have to mess with mine, which i assume is still the original factory trans just about to drive to the 70k mark, if i ever have to touch mine it will either to be rebuild it (my dad will do that) or I will put in one from a Forester.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 05-26-2015, 06:10 PM
I was wondering about those with transmission pans with Fujibond. Mid-1995, 1996, 1997.
Many regularly drain and refill ATF every 30K. Some drop the pan and replace the screen filter as well. Wondering if those who have done that ever had problems with leaks after changing that filter and using Fujibond to reseal.
Old 05-26-2015, 06:12 PM
Many regularly drain and refill ATF every 30K. Some drop the pan and replace the screen filter and clean the magnet, as well. Wondering if those who have done that ever had problems with leaks after changing that filter and using Fujibond to reseal.
Old 05-26-2015, 06:35 PM
well, if these are ANY WAY at all like the 92-94 Turbo Legacy autos, which i am about 100% sure they will be, they ALL will leak at the ATF dipstick tube where it attaches to the trans, the O-ring down there gets brittle and leaks. A leak there, will make one think the pan is leaking, when in fact it is the tube, up front leaking, then dripping/blowing to the back and there is the leak. Every one of my Legacy leaked at that 39 cent generic o-ring. Easy cheap fix too.
- i will probably do the drain and fill in mine sometime in the summer/fall since I have zero records
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 05-26-2015, 06:36 PM
I changed the fluid and filter on my '97 and used the gasket which came with the aftermarket filter. Over the winter all the fluid leaked out because I had not tightened the bolts enough. Better than over tightening though.
No leaks since then in 12 plus months.
Old 05-26-2015, 09:30 PM
Did you remove the Fujibond from the pan and/or the transmission case before using the gasket?
Old 05-26-2015, 09:35 PM
Does anyone have photos or a writeup on the transmission dipstick tube o-ring replacement?
Is it the transmission dipstick tube on the left side of the engine? h ow about the front diff tube?
Old 05-27-2015, 11:27 AM
[QUOTE=svxcess;740449]Did you remove the Fujibond from the pan and/or the transmission case before using the gasket?
.[/QUOTE
Yes I did.
