Exhaust Insulator Pads in the Heat shields
My Insulator pads in my pre-cats are rotted they are in between the heat shield and the pipes.
I'm thinking about replacing them with a Ceramic fiber insulation, all the way around the exhaust pipes then putting on the heat shields. Question if I do this will this cause my pipes to get too hot? will there be any adverse affects? pros doing this less rattle from the heat shield from heat transfer, transmission will stay cooler, engine bay too. cons? less heat dissipation in the exhaust http://www.amazon.com/Ceramic-Insula...ber+insulation Last edited by kjoyes; 08-13-2014 at 05:29 PM. |
Re: Exhaust Insulator Pads in the Heat shields
Designed to keep the exhaust gases hotter from the headers to where they enter the pre-cats.
I removed the heat shields entirely on my 96, have 2" aluminum tubing directly from the headers into the pre-cats. No performance problems or other issues. I am not sure how much measurable difference there would be between insulation and bare tubing for that short length and its effect on performance. I am sure there are various opinions out there. Since insulation works best when it is not as tightly compressed (think home insulation) maybe 1/2" insulation would work better. Insulate and allow some air circulation without being too compressed. http://www.amazon.com/Ceramic-Insula...ire+Wood+Stove .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-13-2014 at 07:47 PM. |
No realistic effects either way
