Charging System Help
I just got a new alternator.
I have done the v.4 alternator wiring upgrade. The old alternator was charging according to advance but had a low output. The new alternator is showing no output. When bench testing both the alternators they tested good. When I put a multimeter on the top post of the alternator it shows 12.5 volts at idle. I am not sure where to start... any ideas??? |
Re: Charging System Help
Where did you buy the alternator? It should put out around 14.2 volts. How old and what condition is your battery in?
battery 3 months. tested fine at advance.
alternator purchased at advance. |
Is it the Advance ToughOne? Most likely it's faulty also. If you want to deal with Advance, I would try the Bosch alternator. It's only $8 more after the core charge is refunded.
here the bosch is 35 dollars more.
the bench test said it was good.... |
i tried using advance for parts at the shop for a few weeks. i ended up replacing every single part i sold under warranty. i learned my lesson and sourced my parts elsewhere but ended up eating the cost of replacing cheap parts with quality ones. ....and advance just bought carquest.
