Parting out built motor
It's with a lot of regret that after 5 years of ownership, I've yet to drive my SVX more than 10 miles. I'm tired of paying insurance on it to sit and rot, so I'm strongly considering picking up a stock motor at the junk yard, dropping it in, and getting it finally moving (hopefully). That leaves me with what to do with the built motor.. I can go through it and work on it over the course of multiple years like I did last time I guess.. But if anyone here is interested in seeking their own turbo dreams, then maybe I can help you out instead.
I would need to go check around the garage and notes to see what all I've got for sure, but some big ones are: - Hydra EMS with wideband. Never used, though some minor tubing/pastic t connectors could be missing. - Custom made 8.5:1 forged CP pistons, from Toms old car I believe - Eagle H beam rods and ARP bolts, bought new. - The timing belt and pulleys are new - Brand new an unmodified stronger WRx engine mounts.. Its been so long I forgot what these are called. Have the used beefier Transmission mount I may or may not keep. - Water and oil pump are new - Bought new ACL bearings, dont know if those are reusable or not. I also have all the stock pistons and rods that came out of it still, and a second spare motor taken apart that has everything put the intake thats available for additional stock parts. Of course, if there is any interest for the whole car as it sits (with the 5 speed conversion kit, 05 WRX transmission, new clutch, aftermarket wheels, etc), thats something else we can discuss. If there is an interest in any of these, let me know. If I have buyers lined up I'll make some time to pull the motor out and break it down. Last edited by STeeL25T; 12-30-2013 at 08:43 AM. |
Re: GI: Parting out built motor
I'm interested in your second stock engine: We desperately need a good crank!
Emily www.ccrengines.com |
I think I have a crank already out of the block somewhere. Let me look around the garage.
Find the Hydra pieces
![]() Might be interested in the pistons and rods. Are the pistons oversize (.020)? PM me. Bill
I have all of it but that jumper harness, and at this point I'm not hopeful that I'm going to find it :\
I am interested in the pistons and the rods, what diameter are the pistons? Feel free to shoot me an email: mike@ moore performance parts dot com
Is the built motor complete/able to run? Would you sell that complete? Last edited by overengineer; 11-13-2013 at 02:37 PM. |
Its all together in the car and hooked up and mated to a WRX 5 speed transmission if you are interested in the whole car. It starts, but dies in a matter of seconds if you dont constantly give it a bit of gas, while smoking quite a bit :\ Theres a few videos of what is doing in my built thread. The tires are terrible from being parked for like 4 years and one went flat during my last test drive so I haven't tried to drive it since, but then it seemed like it didn't want to go over 3000 rpms or so. No idea whats wrong with it.
Weather permitting, I'm pulling the motor on Friday since I have the day off. I might start breaking it down over the weekend if it isn't too busy.
Waiting patiently...
.020 over pistons Hydra ECU Bill
I've gone through all of my PMs and searched through old threads as best I could, but I cannot find the specs on the pistons (other than the part number for the piston rings, if that will help?). I did not bore out my cylinders any bigger than stock so I would assume they are not any differently sized that stock.
Looking crank sensor one (closer to front of engine, next to alternator).
$30 shipped? J
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Is that one of the sensors in the oil pump?
It's the forward most sensor next to the alternator. Right above crank pulley.
Outside of the engine, not inside. Comes out in like 30 seconds. One 10mm bolt holding it on. J
Yes? No? Still alive?
