Old 10-04-2013, 01:57 PM
The Molinator
SVX for SALE!
How depressing.. My SVX has been overheating every week or two.. even after topping off! [Another thread here] Keep topping .. pint or so each time? Dint wanna admit that I saw bubbles bubbling into the overflow reservoir.. After work yesterday, I topped off again.. and siphoned off the excess coolant in the overflow reservoir (almost to top).. This morning, it was close to the top again.. and bubbles bubbling into reservoir, even though coolant gauge showed normal temp! Yikes! I've evidently gone full circle.. back to head gasket problem I had last August.. when I decided to get "new" Nate engine! I have to believe he did the head gaskets.. So, I must have stressed (warped) when first test driving this "new" engine in June (?) when it evidently had air pocket.. I drove home with heater on in red zone .. for about 5 miles ??
Jim
Jim
Old 10-04-2013, 02:16 PM
Re: SVX for SALE!
did you check your radiator cap?
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1956 Plymouth Belvedere - Daisy
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 10-04-2013, 05:02 PM
The Molinator
Re: SVX for SALE!
Yes.. new 2 weeks ago.. New one last nite!
Plus.. overflow reservoir smells like exhaust!
Jim
Old 10-07-2013, 07:19 PM
The Molinator
Re: SVX for SALE!
Theoretically.. this could be cracked head.. if not just gasket!
I don't want to.. but seems like time to Seal and Sell.. ??
Jim
Old 10-07-2013, 09:27 PM
Tireiron Tireiron is offline
Re: SVX for SALE!
Are you sure both head gaskets were done before you got the motor? Or was it just a running used motor? This sounds 100% like a blown head gasket to me.
Old 10-07-2013, 10:58 PM
The Molinator
Re: SVX for SALE!
$2500 for head gskts, bolts, water pump, timing gear, etc .. I assume he did. I overheated on test drive.. for 5 miles after engine install (air pocket?).. sent to CA from PA. Worked good otherwise.. no oil leaks at all. Ultimate Bummer! Marriage .. or head gasket engine out/in? This burned me out. BARR'S Head Gasket Fix sounding better now in this mess..Bought it last year.. but decided to get "rebuilt" low mileage engine.. Now, same head gasket leak I had to start with!!!
Jim
