Looking for manual AWD car
We are approaching the time to teach our son to drive. We want to get a third car and one with a stick so we can teach him how to drive a manual. I would like it to be AWD or at least have a limited slip front wheel drive. I would also like it to be able to get out of its own way, but it doesn't need to be a rocket. I am looking for something with less than 125k miles on it and with no major issues or need for body work. If you see something, let me know. I am thinking 2006ish Impreza or WRX, SVX with 5 speed swap, BMW 330xi or 325xi, late 90s Infiniti i30t or g20t, 3000gt v4r or dodge stealth.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 07-16-2013 at 05:44 PM. |
Re: Looking for manual AWD car
Just an FYI, there are very, very, very few FWD cars with LSD. I can only think of one off the top of my head factory and it's a quite rare car. That being said, I'll keep my eye out. Naturally, I'd ask if you'd consider an Audi, however, I've gotten enough tone to know better
![]() You may want to consider a 99 Impreza RS coupe. I still don't like even the SOHC EJ25's, but they've basically bottomed out in value and are more collectible/desireable than WRXi. Also, depending on the years BMW, I would stay away. They can be great, but are very prone to timing chain tensioner pad failures |
You're not including a price point but if you can find a Jag X Type stick. You'll be able to put him in a car which is as good if not better than everything else listed there and also put quite a bit in the bank for college. Only real issue with the X type stick shift is the transfer case since it comes as a sealed unit (you can change the fluid with a couple methods or kits) and once you do this you have a nearly bullet proof car. Sure the early 02-04 cars have some issues that were sorted by 05 but by this point most of those issues were likely dealt with by a previous owner.
It is simply the most fun I've had driving ours in the snow of any awd vehicle I've driven. The 2.5 has plenty of power, the 3.0 is just icing on the cake. Oh and every time you send in your insurance payment you can put some more college money away compared to the other cars listed. Key with shopping for one is be smart about what you're looking at and if it isn't the right car don't try to convince yourself that it is. Should be in the 70-75k range for around $6-7k for an 06-08. The less options the better as they come stripped about where a Lsi legacy is.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. Last edited by benebob; 07-16-2013 at 01:39 PM. |
I find it funny that you drive a glorified VW and say that Jaguar over complicates things for no reason ![]() It is worth considering and is also as quick as everything else listed as a possibility but benefits from very reasonable priced parts for most everything, a good used parts supply, good insurance rates plus a book value that is simply laughable.
