Bad power steering pump?
So, now that the car is running again, I get to find out all the things that I couldn't when it wasn't. The power steering pump makes a horrible whining/grinding noise when I first start the car and when I turn the steering wheel. The assistance feels...chunky, not smooth.
I assume I need a new pump. Being an LS-L, my car has the speed-sensitive assistance. Do I need to be concerned when I go to Advance and buy their cheapest remanufactured pump? Honestly, I have no idea how that variable assistance works, but I assume the pump itself has nothing to do with it.
Re: Bad power steering pump?
check the o-ring under the reservoir first. a lot more likely then the pump itself. probably have aerated fluid. i'm not certain but i believe the speed sensitive vs. engine speed sensitive is in the rack.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
You know what? Three states and many years ago I replaced that very o-ring. I'll try that tonight for grins, but I don't have a ton of confidence it will work. When I put my stethoscope to the pump, I hear an awful racket.
Thanks for reminding me, though.
Okay, I put a new o-ring in. Hooray for the Harbor Freight giant box o' o-rings!
That did quiet the pump right the hell down. I could even see once I took the reservoir off that it had been leaking. So I can now chalk that up on my list of stuff that I've owned the car long enough to have done twice! The steering, however, still feels...chunky. If I suddenly turn the wheel left and right, there's a hesitation before it will turn left. It's...I don't know, man...chunky. Some of the 'funny feeling' is from on-center. I wonder how much of the stuff I'm feeling is just from the rack sitting in one position for so long. I also wonder if I need a new rack or just need to rebuild the one I have somehow. Has anybody else experienced this sticky or chunky steering?
I had a slipping belt. I never heard it squeal but I replaced it and it became smooth.
Another possibility is that your crank pulley is separating. Mark a line between the outer ring, through the rubber, and to the inner part. Then do some power steering testing and shut it off and see if your line is still in one piece.
You could also try lubricating the 2 u-joints on the steering shaft. They're on the shaft running from the steering wheel to the rack just where the shaft starts to go out of sight under the engine on the drivers side.
This worked on my '92 and my daughters Outback. |
I bought a cheap reman pump for the other car and haven't been entirely satisfied. First it whined. Got quieter with time but now I'm noticing a low-speed clunkiness as you describe. Someone here rebuilds PS pumps (or used to), but I don't recall his handle. dcb |
Could just still have air in the system....jack the front end up in the air, start the car, and turn the steering wheel "lock to lock" a few time to clear any remaining air from the system.
If you need a rebuilt pump, check with Eric (somethingelse) as he was rebuilding them with genuine subaru seals. Not sure if he's still doing it since he moved though.
