code 11... Crank Angle Sensor
What is that all about? first got the 11 code right after my "200,000 mile Burgundy looking SVX" got a engine replacment from Japan and that has been 3 months ago... Happened again yesterday. Engine raced up a couple of times and died as Check engine light came on. I immediately checked for the code and got code 11.
![]() Maybe something wasn't replaced from the old engine that should have been done? I think there are some things that are not compatible... Any ideas, anyone? Thanks, Keith ![]() |
Re: code 11... Crank Angle Sensor
Replace it with a new or known good used one.
That is all |
it is likely the wiring right to the plugs, they are prone to cracking and such
Where might this "Crank Angle Sensor" contraption be found on the car
![]() Thanks, Keith ![]() |
Just below the alternator, mounted directly on the oil pump. It is easy to remove, but you may have to unbolt and lift the alternator out of the way.
![]() Keith ![]() |
