Alternator keeps failing
My altinator keeps failing.
First time I thought it was just because it was time. I had it rebuild at an auto electrician (with a good reputation) After 150 km it failed again. The auto electrician rebuilded it, with out discussion. Now it has failed again after only 200km I have replaced the +wire. Could there be something in the car that breaks it? |
Re: Altinator keeps failing
Keith |
yes. your battery can break it. if the battery is crappy enough to get really discharged every time you start the car then it will burn up the alternator. alternators are good at maintaining a battery charge but not good at charging them up when really far down.
If it is the connector, there is a company that sells them, Northwest electrical supply if I remember right but you need to have a minimum $20 order or something like that. I bought 10 of 'em and easily got rid of the extras.
If its like my car, wouldn't hurt to clean the alternator housing in the spots where it bolts onto the engine and all the mounts. I doubt its your main issue, but any weakness in the grounding here is very quick and easy to fix.
Given the age of the cars, every single little tiny bit of resistance in the electrical system can build into a overall large problem with strange symptoms. |
But you can buy them directly from their distributor Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070 The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum. I already ordered two more. They come with about 3-4" of wire attached; no re-pinning is necessary. .
The batteri has 12.4V now. It is a good qualit and only one year old.
Before the altinater failed it gave 60 amp right after start-up. After 30 minutes driving it gave 25 amp. The altinator was varm. Is this a normal range? I find it a bit high. I guess: Light: ~80W = 6A Fuel pump: ~50W=4A ECU's and sparks: 100W = 8A Fan Hvac: 50W = 4A So around 20A is not that strangs is it? Has any one meassured it? The two white wires has 0 ohm and stabile. |
