Old 02-24-2011, 10:43 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Intermittent tree lights
The problem is exactly as the title states. The past two days, especially today, I've been experiencing my dash lights flashing on and off every now and then. Interior lights seem slightly dim as well. My idle was running a little higher than normal when I stopped at a red light today, right above 1k rpms, which was the opposite of what I suspected it would do. I haven't checked voltages yet, but plan on doing so tomorrow.
I'm guessing it's a faulty alternator? I'm currently using a re-manufactured Maniac. I've already replaced two in the last year
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 02-25-2011, 05:14 AM
Re: Intermittent tree lights
Possibly a bad alt, but also a good chance your crank pulley is separating, put a mark across the front of the pulley, drive it some and see if the inner and outer sections stay aligned....
Old 02-25-2011, 09:28 PM
tiv0's Avatar
svxless
Checked the voltage across the battery terminals:
Idle: 13.85V
Powered off: 12.82V
Also marked the crank pulley and drove ~10 miles. The marks are still perfectly aligned.
On another note, hit a patch of ice in a store parking lot tonight and slid head-on into a curb going about 10mph. Luckily the front end cleared the curb, but my left wheel took a pretty good hit and a 4 inch piece of the lip of the rim broke off. As you can assume, my alignment is now terribly off...
Trevor
Avondale, AZ
1987 BMW 325is
Old 02-25-2011, 09:34 PM
kwren's Avatar
kwren kwren is offline
Idle: 13.85V
Powered off: 12.82V
Was this the voltage reading at the same time as the Christmas tree was going on. If not, it doesn't count.
If not, when they come on, park right then and leave the engine running and test the battery right then!
Keith
Old 02-25-2011, 09:55 PM
Having a plug-in voltmeter is handy at times like this. Put it in the cigarette lighter while driving to get a threshold voltage and watch what happens as the lights dim.
Mine stays permanently installed there.
Old 02-25-2011, 09:56 PM
tiv0's Avatar
svxless
I will look into this.
Trevor
Avondale, AZ
1987 BMW 325is
tiv0's Avatar
svxless
No, the lights were not on; didn't even think of that
It would be difficult for me to attempt to test the battery while the lights come on, because they don't stay on for more than a second at a time. However, if the situation presents itself, I will be sure to do so.
I drove around quite a bit today and the dash lights only flickered at me during a trip this evening, and it was only for a period of ten seconds or so.
Trevor
Avondale, AZ
1987 BMW 325is
Old 02-26-2011, 10:51 AM
Keith
I found this post from Trevor, who is an accredited electrical engineer. I found it to be useful.
The flashing of several dashboard trouble indication lights can indicate an alternator fault.
The indicator light test circuit incorporates blocking diodes to eliminate a sneak circuit which would otherwise exist. In an event involving faults within the alternator rectifier network, often involving only a single diode, alternating current is induced online. As a result, pulses of reverse voltage pass the blocking diodes in the test circuit and energize the indicator lights.
It has been shown that testing battery voltage with a multimeter switched to the alternating current range, will usually disclose the presence of the unwanted alternating current, whereas a straight direct current output voltage check may not.
Those who are testing alternators have often failed to detect this problem, as there may be only a small reduction in DC output.
Old 02-26-2011, 05:36 AM
There is a REALLY good chance that your lower control arm is bent, you should check that out
Old 02-26-2011, 09:41 AM
tiv0's Avatar
svxless
I'm praying that's not the case, but I'll be checking it all out today.
When I bought the car a little over a year ago the company that shipped it to me delivered it in a very similar condition. One of their drivers took it for a "joyride" and smacked into a curb. I replaced a broken rim, lower control arm, ball joint, and had an alignment done...
Trevor
Avondale, AZ
1987 BMW 325is
