Old 02-18-2011, 07:44 PM
3.3H6's Avatar
3.3H6 3.3H6 is offline
Limecat is not amused.
engine noise w/ video
http://www.youtube.com/watch?v=gI9wUQHX3gg
posted a video of the engine running, any ideas? i'm afraid to drive it to the dealer 30 miles away
1992 Subaru SVX: sold after months of problems.
1995 Volvo 850 T5R sedan
2011 Subaru Outback 3.6R limited: excellent all-rounder
Old 02-18-2011, 09:41 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Re: engine noise w/ video
It sounds a lot like two words: "bearing" and "spun"- put them in the order you like, but it sucks either way.
Old 02-18-2011, 09:48 PM
3.3H6's Avatar
****,****,****, etc.
This won't be cheap if it is. oh this is gonna screw my miserable bank account over.
Old 02-18-2011, 10:36 PM
Cam Cam is offline
You can take the oil pan, sump and windage baffle off. This will allow inspection or the rod bearings. You may also check for evidence of a spun main bearing (look very closely at #5). It would most likely be worth it to just get a donor engine.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 02-18-2011, 10:51 PM
3.3H6's Avatar
yeah, that would be great, if I weren't a poor, jobless college student with little time in the week to be doing an engine swap. T-T
Old 02-18-2011, 10:59 PM
Hi Mr. Penguin!
Drain the oil and strain the oil as it comes out through something like a cheesecloth- if the bearings did spin, you'll see the gold residue in the cheesecloth. This will save you pulling the pan off to check at the very least.
You might have gotten really lucky and just blown the bearings in one of the idler pulleys for your timing belt, as it can sound like a spun bearing.
