Old 12-21-2010, 04:25 PM
Huskymaniac's Avatar
Uses the ignore feature
Transmission fluid drain, refill and "how the hell do I read the dipstick!"
After diagnosing my valve cover gasket leak, the mechanic did my second drain and refill of the ATF along with changing out the internal filter. The last time they drained it, only about 4 quarts came out. I brought about 5.5 quarts with me and he said it was still reading low. Clearly more drained out this time. I came home and checked the level again after a 20 minute drive and it did seem low. But, damn, this is hard to read! It looked like it was just above the cold "L" mark. The little hole was filled but it was hard to say how much higher the fluid really was. I added about another half quart but had a hell of a time reading the levels. Clearly it takes a very long time for the fill tube to drain. But I don't want to keep the car idling forever. Do you guys have a procedure to get a good accurate reading on the dipstick? It always seems like there are dry sections all over the stick and wet sections high up the stick.
And does anyone have a feel for how many quarts are needed to get you from the cold "L" to the hot "L" (same as the cold "F"?) and from the hot "L" to the hot "F"?
Tony
Old 12-21-2010, 05:17 PM
kwren's Avatar
kwren kwren is offline
Re: Transmission fluid drain, refill and "how the hell do I read the dipstick!"
...everyone does!
Keith
Old 12-21-2010, 07:19 PM
you could sand the end of the atf dipstick down make it ruff, and paint it a flat black. nothing too smooth. then the atf will stick to it and measure alot easier.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 12-21-2010, 07:27 PM
immortal_suby's Avatar
Thread Killah
I choose to ignore the atf spattered 2 inches above all the markings on the dipstick and go solely with which hole is filled. Dunking the stick in atf is going to fill the holes. Dragging it against atf splashed up the tube can account for the rest of the mess but it won't consistently fill the holes. Right or wrong, thats my method.
Locker Link
2015 BRZ Limited 6MT
Old 12-21-2010, 10:28 PM
Yeah, that's what I was defaulting to. The problem is that my fluid is so clean, I can barely see it on the stick! Now I must knock on wood and hope that it wasn't grossly underfilled to the point of causing damage.
Tony
Old 12-22-2010, 05:55 AM
You will find that if your ATF level is too low, your torque converter will not lock up at highway speeds, or may lock and unlock randomly.
From personal experience on my 96 Polo
Old 01-01-2011, 10:14 PM
I topped off the level the next day. The car was cold so I used the cold marks on the stick. It looked like I got high enough to just barely fill the bottom circle. I figured that was good enough and stopped. I brought the car to the garage the next day for the valve cover gasket change. When I drove it back, the car was warm so I checked the level again. Now it looked like all three holes were filled but the stick was not wetted well. There were voids below the top circle and there was some ATF on part of the stick above the top circle.
This morning I checked it cold again, after cycling through the gears of course and keeping the engine running. The level looked to actually be below the bottom circle?! None of the circles were filled but the fluid looked to be just below the bottom one. So I took the car for a 10+ mile drive with a mix of city and highway driving. Immediately after getting back I checked the stick and the first check showed two filled circles but the top one wasn't filled. My son's opinion was that the fluid looked to be about mid-way between the top two circles. I checked it again and the top circle was filled!!! But, again, the wetting is inconsistent. I even took a wire brush to the stick to rough it up but the wetting still isn't complete and even on the stick. It almost looks like the fluid is splashing up into the fill tube when driving and some of the fluid on the walls of the tube is getting on the stick when I check it. I suppose it is possible that I am just barely at the top circle and so it fills sometimes but not always.
Comments?
Tony
Old 01-02-2011, 12:44 AM
kwren's Avatar
Comments?
Toney, are you also having problems with your transmission not functioning correctly?
Keith
Old 01-02-2011, 01:47 PM
kwren's Avatar
Comments?
The way I see it is you have good news and bad news, Tony...
The bad news is not nearly as bad as the good news is good. The good news that you have no problems with your transmission.. That surpasses, by far, the bad news that you are unable to check fluid level in a transmission.
My comment would be... perhaps for "piece of mind" going back to a Subaru dealer and asking them to recheck your transmission fluid level. My thought would be that they would be willing to do this at no charge.
Granted, there would be some expense for fuel to drive there, but the resulting piece of mine would far overshadow that minimal expense!
That would be my best recommendation.
Have a great and prosperous new year!
Keith
