CAI Feeler
UPDATE 12/28/12
I would like to thank everyone for their patience in this project and would like to release a few details as this project is finally coming to a close. I would like to thank the following members for their contribution to the project. These will be the first customers to receive the new TruSpeed Performance Cold Air Intake for the Subaru SVX Stage II Intake 1.Soobcrazy 2.Nikfu (powdercoat- black) 3.larryhopper1967 4.Thickasxtheives Stage III 1.Johnybeas (powdercoat- black) Prices have been updated to their current cost and should not change. Dyno results, product pictures, etc. will be coming. PRODUCT DESCRIPTION Optional add ons,
TruSpeed Stage I SVX Intake (short ram): $333.60 Dyno Graph(link to results will be placed here) Product Images (link to images will be placed here) Pipe Size: Dual 2.5in(63.5mm)-Single 3 in (76 mm) Material: Mandrel Bent 6061 T6 Aluminum TIG Welded Location: From dual throttle bodys to MAF Sensor Replacement Filter: AEM DryFlow Air Filter 21-203DOSK
TruSpeed Stage II SVX Intake (Cold Air w/ MAF) $390.00 Dyno Graph(link to results will be placed here) Product Images (link to images will be placed here) Pipe Size: Dual 2.5in(63.5mm)-Single 3 in (76 mm) Material: Mandrel Bent 6061 T6 Aluminum TIG Welded Location: Full piping from throttle bodies to wheel well with separation for the MAF sensor Replacement Filter: AEM DryFlow Air Filter 21-2038BF
TruSpeed Stage III SVX Intake (Cold Air w/ Air bypass) (*requires MAP Sensor*) $419.99 Dyno Graph(link to results will be placed here) Product Images (link to images will be placed here) Pipe Size: Dual 2.5in(63.5mm)-Single 3 in (76 mm) Material: Mandrel Bent 6061 T6 Aluminum TIG Welded Location: Full piping from throttle bodies to wheel well with AEM Air Bypass Valve in stock MAF location. Replacement Filter: AEM DryFlow Air Filter 21-2039BF
Package Includes:
Here is a picture of the final prototype of the stage III ![]() Last edited by Johnybeas; 12-28-2012 at 01:40 AM. Reason: Prices and specifics/Material Changes |
Re: CAI Feeler
I'd buy one iffin it was around 400$ any more would require more serious consideration but at or below 400 sign me up
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
Re: CAI Feeler
Updated with approx prices and specifics on kits.
Re: CAI Feeler
So long as there are brackets to keep it from vibrating/flopping and is of high quality and close tolerances, I would be interested in the stage 2 CAI.
Re: CAI Feeler
Johnny, would the stage 1 kit essentially be similar to the tommyX intake that Tom was offering? That's what I get from reading it but just checking. The prices seem good.
Re: CAI Feeler
yes it will be similar to the tomyx but with a filter included in the kit
