I keep hearing that the O-Ring fix is a "way to solve all your power steering problems." I've read posts that say it will stop the leaks and puddles of PS fluid on your driveway as well as help your PS pump when your car is at low speeds. It also cures jock itch and laziness. Could someone clear this stuff up and possibly submit it to the FAQ? See, my problem is the underassist when at low speeds but I've never seen a puddle of PS fluid except for the dried stuff that always ends up on top of the resevior tank and I can smell it burning under high acceleration. (which has nothing to do with any of the symptoms that showed up in the first 120 posts at the Wahoo! board) I don't ask for help (as in a direct fix) so much as somebody puts in their $.02 because it's really confusing. (yeah, confusing, that's what I want, someone to lift the great cloud of confusion from my smog ridden head)
-Craig Lowthorp, Flagstaff AZ '92 LS-L, Black on White, 136k SOLD '92 LS-L, Black on Silver, 120k SOLD '01 Legacy Outback, White, |
Okay, Craig. Here's the deal. The O-ring fix is not a "cure all" for your PS pump woes. It is the first thing you try though, because it is the least expensive fix you'll find for an SVX.
Here's what happens: when the O-ring between the pump and the reservoir deteriorates, it creates an occasion for the pump to suck air. It "foams up" the fluid and reduces pressure in your PS system, which gives you those little "shudders" when turning at low speeds as well as that nasty whining or groaning noise you get when turning the wheel. The reason the fix is suggested as your FIRST line of defense, is because it costs about 3 bucks and less than an hour of your time. If it cures the problem, then, you're good to go and you're happy you didn't have to spend around 500 bucks for a new pump. Cheap, quick and easy. If that doesn't turn out to be your problem, then, you take the next step and replace the pump. The thing is, over the years, SVX owners have been told they needed to replace their power steering pumps when these symptoms occur, and they really didn't have to. Understand, also, that you don't have to have puddles in your driveway to need this repair, just the symptoms mentioned above. There may be little or no fluid loss from the deterioration of the o-ring. Under most cases, though, there is a puddle behind the reservoir on top of the engine. So, if you're having trouble with your PS pump, first, check the hoses for loose clamps, hardness, cracking -- the usual stuff. If all's in order, change the O-ring, your problem may stop there. If it doesn't, then you may need one of two things 1) A new PS pump 2) (and hopefully not) a new steering rack. Now, have I sufficiently confused you? All this info is based on personal experience. My car displayed the symptoms described when I first bought it. I saw the O-ring fix on the KC site. I went to replace my o-ring and didn't have to -- I had to INSTALL it (there was none). Since then, no shudder, no whine and no fluid puddle on my engine. So, there you have it. But since I'm not a licensed and certified Subaru Technician, you'll probably just want to forget I even typed this. ![]()
cures jock itch
Why wasn't I informed of this!? The AC is out on my SVX and there is a cure for jock itch out there and no one told me about it!? And here I thought you guys were my friends.
![]() Under assist at slow speeds. I cured this by not driving at slow speeds. ![]() |
Re: Power Steering (not O-Ring)
And, the o-ring fix does not cure laziness. Believe me. I've done it, and I'm STILL lazy. ![]()
STILL lazy
There are some in this world that confuse serious efforts at procrastination as laziness. When someone is constantly changing your priorities how are you ever supposed to schedule them into an effective plan? I usually wait for the dust to settle before taking action.
![]() And, aredub, could you please direct me to the o-ring replacement instructions? While I wait for the priorities to gel I just might spend the hour getting coated with PS fluid. Thanks |
O-ring Fix
After replacing my totally crushed power steering o-ring I took a larger o-ring which came in the variety pack (multiple sizes) and stretched it to fit inside the reservoir cap. It now closes nice and snug and no more fluid residue on top of the reservoir.
I'm doing this today. I think I'm having PS problems, not AWD binding issues.
- Ca$h |
Re: power sterring o ring
I thought all was good when I bought my car and signed up to the board here. Now I notice the condinsation in the tail lights and cloudy headlights. I have also started getting the lovely steering noise. My lights on my radio come on when they feel like it. After all this you would think that my sun visor would flop.....oh wait IT DOES!
![]() Stop sending bad vibes to my car. ![]() Just in case you think I'm serious....I don't blame you yet. ![]() I think it's my Tempo of Doom that's causing the problems. It seems jealous. Scott |
![]() Quote:
Please note that some seepage is also permissable when consuming Olestra processed food products. No acceleration necessary. PS - Anyone seen Lightening around lately? Ron.
Good s**t happened. ![]() '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Osbornes
Who needs to watch the Osbornes when there is entertainment like this available?
SVXROO |
Re: Osbornes
![]() ![]() ![]() True, ROO. So True. ![]() ![]()
Re: Re: Re: power sterring o ring
Doug
![]() Quote:
Ron.
