AutoMD
Has anyone played around on this website?
http://www.automd.com Lots of information here. You can type in your car and symptoms and see where it takes you. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Re: AutoMD
Great site. I'm still looking for the best way to refresh the interior smell. My wife complains it smelled like old car...
The trunk still smells like new car though!
-Ryu Links: 2004 Honda S2000 (2008~) 1992 Subaru SVX LSL Liquid Silver (2007~2008) 1996 SVX LSi Bordeaux Pearl (2006~) 2002 Lexus IS300 Sportcross (2005~) 1992 Subaru SVX LSL Pearl White (2001~2005) 1994 Mercury Sable GS (1999~2001) 1/43 Scale SVX Models [SIGPIC][/SIGPIC] |
Re: AutoMD
I would say the interior smells can be from a few places in particular in these cars as far as I have seen.
#1 the carpets. Remove your seats and interior pieces to be able to completely remove the carpet (this is the best way to do this but not the only way) Once you have the carpet out of the car I would suggest steam cleaning it to help remove the stains and years of spillage. Also the carpet may have mildew from moisture so treat those areas as you see fit ( ![]() With the carpet out I used a slightly diluted purple power to wipe down the floor and clean all stains, where ever you have rust such as the bolt areas for the seats clean that up and spot paint the area to treat it. Then reinstall carpet. Unless you want to apply sound deadening prior to install! #2 door panels and doors, I would recommend pulling them and cleaning behind them this would be a good time to upgrade speakers and apply sound deadening for your doors. I have been considering a combinination approach. If you got $$ to blow use dynomat, if you want a decent qualit product that is pretty much the same or better use the edead sound deadener (can be found on amazon). Also check out http://www.sounddeadenershowdown.com/ New stuff and cleaning always helps with the smells. #3 the headliner and the escaine panels should be cleaned as well. #4 this one adds alot of funk to the car when in use. The heat and A/C vents I don't remember if this car has a fresh air filter but I believe it does. basically use a bleach water mixture in a spray bottle and spray it in the air inlet and some in your vents while the system is running. If you don't want to use bleach use some vinegar, it will stink it up some initially but should kill any mildew. |
