Wheel experts have a look!
Brought one new wheel home for a test fit onto the TVR today. Take a look and give your opinions they are a 15mm offset and 7.5 inches. They stick out about 1/2 to 3/4 of an inch more than stockers which were 14sx7 with a 25mm offset. Inside their out about a 1/4 of an inch. This was the only one my tire guy could find that he thought would work. Ya think I'll have issues with rubbing or not? How do you think they'll look? Oh and they're also a little more bling then I'd prefer but at least they're round. Planning on 205/45 16s or if I don't have any issues with rubbing 205/50 16s. Might go to 215s too.
http://s185.photobucket.com/albums/x.../TVR%20Wheels/
Re: Wheel experts have a look!
10 characters.
Car is running and most all the electrics work. I'd say it idles around 85-90 decibels with a very mean pushrod sound. ![]()
Honestly, I think they're too flashy. Too much chrome, and not sporty looking enough. But that's just my opinion.
It may be from a Miata website: but you can use this to compare your stock tire/rim size to what you're planning, to see how much difference there is. http://www.miata.net/garage/tirecalc.html It may not tell you if they rub, but you could like, measure it or something I'm sure. P.S. What kind of car is that?
Current Vehicle: 1994 Cadillac Fleetwood Brougham (LT1) SVX Purchase: TBD <- Very delayed, but it will happen. Jacksonville University Class of 2013 |
Friends don't let friends put chrome wheels on sports cars Ben
![]() Just say NO to chrome
Down to none ![]() |
Don't be haters! Let brother Ben roll with his AMG-ish bling rims!
![]() -Bill
I don't care for the chrome or the M-class look of them on such a clean little British sports car. I know that around here getting the wheels round again isn't that expensive, but I don't know what it cost to get them painted, blasted, or polished (whatever the finish you would like them to be) and the fact that you can't find the center caps sucks too. If you buy these just get the car driving would you be able to sell them and recoup most of your investment on them when you can get more 'fitting' wheels for the car? As for the tire availability.....Why Z rated? Is a re-drill an option that would offer up more wheel choices?
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." Last edited by YourConfused; 06-26-2009 at 09:19 AM. |
Chrome is not necessarily a problem... classic cars have lots of chrome details. But that flat-face wheel design doesn't suit that car much at all. It isn't a late-80's, early 90s Mercedes Benz.
This car is begging for Panasport/Minilite-style wheels. Several brands offer them... Panasport ultralight: (may or may not offer 5-bolt pattern...) ![]() Rota RB: (although only in 5x100 bolt pattern, or 4-bolt.) What is the bolt pattern on that TVR? It is obviously 5-bolt from the pictures... but somehow I thought some old TVRs had 4-bolt hubs. Being british, and older... I figure it is probably imperial measurement, and probably 5 bolts on a 4.5 circle. (5x4.5 = 5x114.3, same pattern as SVX, coincidently.) If all else fails... there are these: MB Wheels Mesh X, 15 inch diameter, 6.5 inches wide (good for 205mm tires), 38mm offset. Even if the offset is too high, it is easier to add thin spacers to lower the offset, than to fit low offset wheels to cars like Subarus, which require very high offsets. http://www.discounttiredirect.com/di...1&wd=15&rw=6.5 ![]() Liquidmetal Static: a more modern design, if you really want a resto-mod look... (classic car with modern wheels...) 15x7, 38mm offset, again, spacers are available to lower that number. http://www.discounttiredirect.com/di...r=1&wd=15&rw=7 ![]() 7-7.5 inch wide wheels, with shorter sidewalls, are starting to get into 215 or 225 width tires. Classic sports cars don't really look good (actually I don't think ANY car looks good) with tires narrower than the wheels. On cars built during the bias-ply tire era, even fitting radials to them, I would probably stick to a 50-series tire, and at least as wide as the wheel, if not a slightly over-sized width fitment, if it will fit in the old, narrow-ish wheel wells. For 7.5, I would probably go with 215/50, or maybe even 225/50 or 215/55 For something closer to 6.5 or 7 inches wide, 205/55 or 215/50 as a wide fitment. 40 or 45 series might be a little short on sidewall for a car built for the Bias-ply era.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. Last edited by BoxerFanatic; 06-26-2009 at 09:32 AM. |
Check out the Panasport wheels at Moss Motors (British Car Specialists)
http://mossmotors.com/Shop/ViewProdu...eIndexID=71614 Panasport Wheel - 16" x 7" Note: Weight 17.10 lbs, offset +22mm Gene
Again, posting pictures of wheels that don't fit isn't really any help
![]() Out of round is about $100 a wheel, cracked rims like I have are just going to crack again. Refinishing add $150 or so a wheel.
Any thoughts on these? (which I like but only the silver is availabe in a 5x112 (at least according to one ebay site but this site doesn't list 'em in that size). They would still stick out 9mm more than stock
http://www.esmwheels.com/Wheel_002.html or these (which I hate BTW but fitment wouldn't be an issue) http://www.discounttiredirect.com/di...r=5&wd=16&rw=7 or these (which I hate less a bit then the ones right above) They'd stick out at least 4mm than stock, more if I need to put a spacer to make up for the 8mm loss inner. http://www.discounttiredirect.com/di...6&wd=16&rw=7.5
Like Todd and the guys are saying, chrome wheels on an English sportscar are a total no-no. Don't go there man. That looks a very neat car, you will ruin it. Also, to leave it even marginally authentic you need to replicate the deep dish route of the wheels you have on there. These are the wrong style to suit the car, and the fact that they are chrome to boot just makes them ![]() Your car, your choice, but you would be making a big mistake. Joe ![]()
