$5, 5 minute droopy visor fix
$5, 5 Minute droopy visor fix
Sick of messing with those droopy visors or don't want to pay to get new ones or the current ones fixed? This $5, 5 minute method will solve your problems! Before: First go to RadioShack and buy the following 2 items: The magnets come in a 2 pack. Do not get the glue on your skin! It is very fast acting and strong! Use the glue on one side of the magnet and place it on the visor: Place glue on the other magnet and firmly press into the area above the other magnet. You may have to apply more glue and repeat for the glue to soak into the cloth. IMPORTANT: Make sure you have the magnetic charges opposite so it attracts, and not repels. Make sure the magnets will touch! And once dry you'll be done and without a droop! After: |
Re: $5, 5 minute droopy visor fix
the fuzzy part of your headliner will be dropping shortly. how will you fix that?
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Mine is still in good shape, so that's a non-issue right now for me. Plus the magnets weight next to nothing so they won't pull down on the headliner much if at all
Its not the magnets that pull it down, its the weight of the visors. This is about as good as the velcro mod...
I have always wondered, what if you could slip a strong magnet inside the visor, wouldn't it be attracted to the metal in the roof? Or is the headliner too thick for this to work?
A strong bar magnet should be able to do the trick. A thin strip may not...
Correct. Your headliner will be toast after this mod.
