my car drives great untill a certain speeds are mixed with certain degree of turning and i get vibration in the steering?
could it be wheel balance? or is it a lil more technical and exspesive then that...? do bushings have anything to do with steering cause my front ones are gone (pickin new ones up from motorsport once my i get my new altornator) this has been happenin for a long time...but happens usually at highway speeds (50-85)
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
Re: vibrations when i turn...?
Could be both. Two out of balance wheels on an axle will have different degrees of vibration depending on where the position of imbalance is relative to each other. Bad bushings allow excessive play and can cause the same thing. If the tires are still good, id get them rebalanced as wear will change the rubber content and nullify the weight balance applied when newly installed.
ok, i'll do that this weekend then and see what happens
thanks So-Cal
