Old 04-11-2009, 08:51 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Angry low beams not wrkin!!! AGHHHH!! HELP PLZ!!
never had problems with my cars lights till today
due to the rain i used my headlights like usual to and from town. i stop at my friends house and as i leave his house i start my car and turn my headlights on. (it was dusk). all is normal till the battery light, tail light out , and brake light on the dash stayed on. i put the car in drive and took the e-brake off to see what happens and the car seemed to drive fine with the exception of the dashh lights (and headlights probably not on with the switch on)
after driving a little way and came to a stop, the lights faded away...then i stepped on the gas and they came back! not only does steppin on the gas make those 3 lights go on, all the interior lights get brighter as well.
the hi-beams work and so does the dimmer but the low beams dont. is it the switch and short?
i checked the fuses and all are good.
2 possibles causes are:
i left my windows craked open a about 2-3inches and it rained (dont think much rain got it cause when i got in, it was pretty dry)
and the other is i put a tranny temp gauge in and tied the gauges light wire to the parkin light button, the needles power to the stereos on wire to the stereo, and the dimmer to the dimmer that leads to the stereo
any help or hints would be appricated....i need the low beams to wrk so i can get to werk on monday!
Old 04-11-2009, 08:56 PM
Green1995SVX's Avatar
Re: low beams not wrkin!!! AGHHHH!! HELP PLZ!!
Do you have stock headlight bulbs?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-11-2009, 09:03 PM
VICSVX's Avatar
Never Forget
no, i did the headlight mod....
Old 04-11-2009, 09:13 PM
Manarius's Avatar
Manarius Manarius is offline
HID's? I bet that your alternator is going bad and that your high beams work because they don't require the same amount of constant draw that the HID's do.
-Jason
-Obi Wan Kenobi
Old 04-11-2009, 09:18 PM
VICSVX's Avatar
Never Forget
no not the HID, the one where u get 9005 and drill out the notch....ive had them in for almost a year with no problems
Old 04-11-2009, 10:33 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
How did you connect your wiring with the gauge? Please, don't say vampire taps...
If your high beams work OK, then your low beams' only opportunities for problems include the wiring from where the high beams and low beams meet on the positive side to the bulb, from the bulb to ground, and the bulb itself - not much!
This sounds like another voltage regulator slacking off.
