AXLE, Front
While starting to do my front brakes, I noticed a large tear in my outer axle boot (driver side). I think I've replaced this axle twice...First time I purchased the axle (Pep Boys), the second time I got it free on Lifetime Warranty (I think).
Should I replace the axle, since I don't know how long the boot's been broken. There is no blob or large amount of grease inside the broken boot, so I'm assuming it tore quite a while ago. Should I try to replace the boot only as shown in the shop manual? Is that easy to do? Sorry for the senility...but I almost died in September from chemo I took to treat the cancer I got in August. I can't remember how to replace the axle, even though I've done it twice...Ha! Do I remove the lower ball joint, leaving the rest of the supporting structures intact...to remove the axle (to either replace the boot..or to replace the axle)? Also, I didn't do the front disc and pads, because I was afraid I would have to remove the calipers/rotor for the axle.. Do I have to? Sorry I have to bother you with this basic info, but I would sure appreciate your help.. . ![]() Thanks, Jim ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
Re: AXLE, Front
It is easier to replace the whole axle and a lot less messy rather than just replacing the boot.
Re: AXLE, Front
OK!.. Do I have to remove the rotor/caliper?.. or can they remain attached during axle replacement? It seems like I just detached the lower ball joint (3 bolts) to pull the suspension out of the way to get axle out.. ?? Is that right?
Thanks.. . Jim ![]()
Re: AXLE, Front
OK.. I found the "How to" thread for front axle.. . Never Mind!
Re: AXLE, Front
It's pretty easy to follow. I was about to send it to you when I looked last time.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Re: AXLE, Front
that is your problem. take some advice, get a subaru oem or mwe axle. and be done with it for good. or, don't listen to me and have vibrations and replacements required every 6 months or year.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
