Old 10-30-2008, 05:05 PM
kwren's Avatar
kwren kwren is offline
Emission test failed
Too much unburnt fuel out of exhaust.
Any ideas?
Old 10-30-2008, 05:56 PM
Re: Emission test failed
O2 sensors come to mind first. MAF sensor perhaps?
Old 10-30-2008, 08:19 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Run a good fuel system cleaner through a full tanks worth of driving, and if your plugs are old or you are unsure of their age/condition, replace them. Also check your air cleaner and find any possible vacuum leaks. Good luck
Old 10-30-2008, 09:50 PM
kwren's Avatar
All great components suggested above. How is the best way to check for a vacuum leak... ?
Thanks to all,
Keith
XT6Wagon XT6Wagon is offline
also before you get tested drive it till its warm, then drive around for a few in a gear or two too low so the RPM's have to stay high. The point is to get the cats HOT HOT HOT so they work the best.
Last edited by XT6Wagon; 10-30-2008 at 09:50 PM. Reason: edited for greater clarity
Old 10-30-2008, 11:27 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
A good way to check for vacuum leaks is to use about a 2 foot length of 1/2 or 5/8 inch hose and put one end to your ear and the other use to probe around your vacuum lines. If you hear a loud constant hiss, bullseye. Id also try driving a long distance at freeway speeds to burn out combustion deposits (if you do mostly local driving), and dont forget to run the fuel injector cleaner thru. Dirty injectors can cause too much unburnt fuel since they squirt instead of spray, causing incomplete combustion, or something is causing the computer to enrich the mixture too much, such as a vacuum leak or sensor malfunction. No check engine light on?
Old 10-31-2008, 11:37 PM
kwren's Avatar
30 miles on freeway at 70ish on the way to test. Didn't do the drive around in lo gear though but will try that on the way to retest
Old 11-01-2008, 06:06 AM
I think others have basically covered it with the sujestion of: O2's, MAF, vac or exhaust leaks, bad cats, or old plugs. Didn't you have the t-belt done recently? The only other reach I could see would be leaking injectors or a faulty FPR.
blk 92' LSL w/ average mods
Old 10-31-2008, 11:35 PM
kwren's Avatar
I use fuel system cleaner about every 2-3 fill ups
Old 10-31-2008, 11:33 PM
kwren's Avatar
new o2 sensors twice (subaru)
Cleaned 2 MAFs twice!
Old 10-31-2008, 03:10 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Oh yeah, was it failed on idle or revving? Sometimes you can get a cool tech that will let you rev the engine slightly at idle up to the limit on the tester to pass you at idle if thats the problem. Not sure if your emissions procedure is the same as here though.....
Old 10-31-2008, 04:25 PM
ZMan's Avatar
ZMan ZMan is offline
You might want to try this - I haven't used it, but you can read reviews at this site, all positive.
http://www.amazon.com/Guaranteed-Pas.../dp/B0007N1ZPY
Old 10-31-2008, 08:01 PM
wantafastsvx wantafastsvx is offline
Probably a silly question since you have emissions to test but is the exhaust factory? Still have all three cats? Just a thought again probably a moot point
Old 10-31-2008, 11:29 PM
kwren's Avatar
Got it all!
kwren's Avatar
exhaust system is factory.
