Old 10-06-2008, 01:05 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
front right cv boot replacement help
my passanger side cv boot took the dump....its toar to hell.
any body know how to change one or would it be easier to just buy a new axel?
obtw...need a new frond diff too...its cracked just above passanger side axle
Old 10-06-2008, 01:16 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
Re: front right cv boot replacement help
they are a easy replacement just pound the key out with a 3/16" punch, unbolt the ball joint from the control arm and remove the axle nut from the end of the shaft.. and yes your going to want to replace the whole cv shaft... as far as the front diff goes you need to remove the transmission to get it out.
- John
Old 10-06-2008, 11:35 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
http://www.subaru-svx.net/photos/files/How-To/42663.doc
Link to the How-To
It's a big help if you pay attention.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 10-07-2008, 06:57 AM
VICSVX's Avatar
Never Forget
thnx i'll give that a try...the link seems very helpful so.....
hmm, but that seems to replace the axle...what about the boot?
im tryin to save some money: cv boot cost $13 and new axle costs @115
Old 10-07-2008, 08:01 AM
I have a couple of boot kits I bought before deciding it was safer to replace both. I will see what comic book came with them.
The Worm
_______________
No Mods, 33K Miles
Old 10-07-2008, 08:23 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
All boot kit's that I've used come with instructions. Also, you didn't mention which boot needs replaced? To replace the outer, you need to take apart the inner, so you'll need a second boot kit (or at least the clamps)
WARNING Replacing boots is a big mess and will result in axle grease everywhere in your shop or work area. Have a roll of paper towels and a lined trash can nearby. Pay close attention to the direction of how things come apart. You'll also need a pair of snap ring pliars, and some boot kits require a special tool to tighten the clamp. Try to find a kit that doesn't.
And the $115 for a new axle sounds high?? Have you shopped around??
