Old 04-06-2008, 04:06 PM
SVX trim code registration: please submit your details
We need your help to compile an accurate list of the available interiors for the SVX, world-wide.
Already we have compiled a chart of the available colors, and their correct codes. Now we want to do the same with the interior trim with your help.
Above is a jpeg of a UK VIN plate. On it you will notice on the left a line called "Trim Code", and this code is 320 for this car. "Option Code" is on the right side, in this case it is BK.
Earl has already done a very fine pdf listing the USA trim types.
What we want here is to identify what each Subaru code applies to for all SVXs world wide, and you can give us this information.
Can you please insert the required information as it relates to your SVX by using post 2 as a "quote" and filling in the information for each question?
By this I mean reply to post #2 using the quote button on the bottom lhs, and then deleting the first part of the reply that will start with [quote=svxistentialist;539569]
Thank you.
Old 04-06-2008, 04:07 PM
Use this post as a template. Delete the quotes.
Your model year:
Your vehicle color:
Applied Model Code:
Color Code:
Trim Code:
Option Code:
Leather upholstery?:
Upholstery color:
Door card color:
Steering wheel/ Shifter color:
Ecsaine on dash color:
Carpet color:
Other information?:
Old 04-06-2008, 04:12 PM
Information for '95 UK car in VIN above
Your model year: 1995
Your vehicle color: Liquid Silver
Applied Model Code: CXWBK7E
Color Code: 249
Trim Code: 320
Option Code: BK
Leather upholstery?: Yes
Upholstery color: Black
Plastics color: Dark Grey
Steering wheel color: Black
Ecsaine on dash color: Purple
Carpet color:[/quote] Black
Other information?:
Old 04-06-2008, 04:19 PM
The underlined ones are from the VIN plate
Your VIN plate should be on the top of the suspension turret under the hood.
The four underlined questions above will come from the vin plate.
Your identifying exactly what trim you have will help us identify exactly what each Subaru code refers to.
This will be an aid to members refurbishing and rebuilding cars in years to come as SVXs get more rare.
Thanks in advance
Old 04-06-2008, 06:14 PM
Your model year: 1992 JDM RHD
Your vehicle color: Liquid Silver (3 tone)
Applied Model Code: CXWA23E
Color Code: 215
Trim Code: 220
Option Code: BYC
Leather upholstery?: No, Leather & Escaine
Upholstery color: Grey
Steering wheel color: Grey
Ecsaine on dash color: Grey
Carpet color: Grey
Other information?:
Old 04-06-2008, 06:19 PM
Your model year:
Your vehicle color:
Applied Model Code:
Color Code:
Trim Code:
Option Code: CXWA23E
Leather upholstery?: Escaine
Upholstery color: Gray
Plastics color: Dark Wood Grain
Steering wheel color: Gray
Ecsaine on dash color: Gray
Carpet color: Gray
Other information?:
Thanks Earl.
Good, but incomplete. [Edit - you fixed it. Perfect job]
Did you use post #2 as a "quote" to pull down the template?
[and then delete the quotes]
Old 05-04-2010, 02:56 PM
NeedForSpeed NeedForSpeed is offline
Re: SVX trim code registration: please submit your details
Color Code: 215
Trim Code: 220
Option Code: BYC
Carpet color: Grey
Other information?:
Earl,
Did you mean Option Code BXC?
I don't have a BY code for Version E listed here:
http://www.subaru-svx.net/forum/showthread.php?t=54435
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 04-06-2008, 06:08 PM
Manarius's Avatar
Manarius Manarius is offline
Your vehicle color: Polo Green
Applied Model Code:CXWDY7E
Color Code: 517
Trim Code: 540
Option Code: HN
Upholstery color: Tan
Plastics color: Tan (Wood where in the L models would the ugly plastic would be)
Steering wheel color: Tan
Ecsaine on dash color: Tan
Carpet color: Tan
Other information?: Dual Front Airbags, ABS, Sunroof
-Jason
-Obi Wan Kenobi
Old 04-06-2008, 06:15 PM
Brilliant, Manarius.
By plastics color I am asking what color your dash plastics and shifter and door panels and so on look like.
[Not the wood trim]
Thanks
Old 04-07-2008, 04:55 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Thumbs up
What a cool project I hope you can get it figured out. At the very least, you should be able to get a list of all the different codes.
Model year: 1992 JDM VL
Your vehicle colour: Claret with black roof
Applied Model Code: CXDA25E
Colour Code: 265
Trim Code: 220
Option Code: DXC
Upholstery colour: Black
Plastics colour: Dark wood grain
Door card colour: Black
Steering wheel/ Shifter colour: Black (leather)
Ecsaine on dash colour: grey with a hint of purple
Carpet colour: Black
Other information: No Airbag, No Sunroof.
Your vehicle colour: Black
Colour Code: 235
Trim Code: 220
Option Code: DWC
Other information?: Airbag, No Sunroof.
Your model year: 1994 JDM S40ii
Your vehicle colour: Emerald
Colour Code: 434
Trim Code: 410
Option Code: 9X
Upholstery colour: Grey
Plastics Colour: Dark Grey
Door card colour: Grey
Steering wheel/ Shifter colour: Grey
Ecsaine on dash colour: Grey - fake leather NOT ecsaine.
Carpet colour: Grey
Other information?: ABS, Cruise, No Airbag, No Sunroof.
I'll check my friend's car tomorrow and post that too.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-07-2008, 06:21 PM
Thanks Phil
Good info.
When did you get the black Version L? That's new, isn't it?
Old 04-08-2008, 02:17 AM
b3lha's Avatar
Phil & Belha
Talking
Thanks Phil
Good info.
I got it around the time Ashwina was born. It was donated to me for free by a member here. He said that it needed some work doing and he wanted to see it go to a good home rather than to someone who would break it for spares. I was rather overwhelmed by his generosity.
There doesn't seem to be very much wrong with it. It's only done 100k miles, runs sweetly, the gearbox works OK, it passed an MOT and it's probably in slightly better condition than the claret.
Old 04-08-2008, 06:34 AM
AUSVX AUSVX is offline
Registered Loser
no problem, I'll do my registration again soon, just too busy to look at the moment. i guess what i filled out was better than nothing... but my car is the exact same spec as "Brady" (if he has filled out a registration)
Old 04-08-2008, 06:53 AM
It looks good in the email you sent me.
That was indeed generous of him. He obviously loves the SVX, didn't want it to be scrapped.
I live in the wrong country.
Old 08-14-2008, 04:31 PM
SVX_MY_BABY's Avatar
Your vehicle color: Dark Teal
Applied Model Code: CXWAY7E
Color Code: 269
Trim Code: 210
Option Code:
Plastics color: Grey
Steering wheel color: Grey Leather
Carpet color: Grey
Other information?:
