Old 11-02-2007, 07:39 PM
Questions on 99 Legacy Motor swap. Anyone?
Well, as some may know, I am trying to get a 98 or newer Legacy for Jon, my better half, and I have this deal secured on a 99 Legacy SUS (Outback Sedan) that needs a motor. I am trying to figure out what I can do besides the original 2.5L into it. I heard I HAVE to get a motor from a 99. I was wondering what Id have to do to use a motor from a different year or is an EJ22 swap possible? I just want a less expensive alternative. I don't mind swapping some exhaust parts... Anyone know?
(I did post on Legacy Central as well, but I just signed up, and wanted to see if anyone on here would know...)
I
Old 11-02-2007, 08:16 PM
I know the SUS is a neat car and that's about it. I almost bought one instead of the SVX.
blk 92' LSL w/ average mods
Old 11-02-2007, 08:33 PM
subeman90's Avatar
Soobologist
I don't think you need a 99 motor per se...you just need a 2.2 that is OBD2 to go in there. Also note that the 99 legacy motor (2.2) is an interference engine so you know how that can go too.
There is a lot of talk about people doing this in their OBWs over on USMB so go do a search and have a good read over there. I might even have something over there in the repair manual (that I am the moderator of) so have a look there too.
15 OBW premium w/eyesight
Old 11-03-2007, 12:50 AM
Hondasucks's Avatar
Subaru Technician
the 2.2 is not interference, only the 2.5L DOHC is interference.
1986 VW Jetta
Old 11-03-2007, 07:08 AM
subeman90's Avatar
Soobologist
the 99 2.2 is interference. Check your sources.
Old 11-03-2007, 08:23 AM
crazyhorse's Avatar
242,000 mi on oem trans
An EG33 ought to fit the 99 Lego quite nicely. After all it has the good gearing to start with, and it's lighter.
I never did understand why Subaru didn't use the EG33 in the Lego. I think the original Outbacks would have benefitted from even a "detuned" H-6
"42"
Current Stable By Age:
Old 11-03-2007, 08:49 AM
ccrinc ccrinc is offline
Send a message via AIM to ccrinc
All Subaru engines after '96, even the EJ22s, are interferential with the exception of the '97 EG33. (And it's finicky.)
The '99 EJ22 is a hybrid of a 2.2L and the EJ25 SOHC. It was also used in the '99-03 Imprezas.
It is unclear whether an earlier EJ22 will swap. While a '95 EJ22 will swap nicely into the '96-98 Outbacks, after that there are issues with 4 bolt vs. 8 bolt bellhousing patterns and possible incompatibility of the ECU to deal with.
In fact, are you sure this is an EJ22? I thought I remembered the SUS having the EJ25 DOHC in it. (But it's really early, and I've only had half a cup of coffee, so my memory isn't at its best right now.)
Emily
http://www.ccrengines.com
Old 11-16-2007, 04:19 PM
Octanerush Octanerush is offline
I
i do alot of engine swaps on subys.
i just did an engine swap on my g/f's SUS 99. u can use any ej25 engine as long as you check the bolt pattern on the intake manifold. u gotta swap the whole manifold(wires n all) from the old engine to the new engine. this will solve alot of electrical problems.
also if ur car has an egr valve. u gotta drill a whole into the block of the jap engine (they don't come with egr valves)
hope that helps
[M]i[K]E[¥]
