Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
Old 10-17-2007, 03:50 AM
svxual's Avatar
svxual svxual is offline
can it b done?? toyota = svx
was wondering if anyone has tried any other supercharger other than the ones made for the svx.. eg..from2tz 2.4 4cyl estima van these ones have a throttle body/tps and air bypass built into air intake pipes basic super charger is the same they dont require any feed and are a good little unit that dosnt give any trouble will suit engines up to 3.8 litre petrol or diesel a mate had one on a 2.8 hilux and it went awsome (10 lbs boost) boost is controlled by belt pulley ratios they have an electric clutch but can be locked
Old 10-17-2007, 03:58 AM
Hmmm... svxual, you should be careful bro where you post on the forum. This belongs to the mods section.
EDIT: Transferred to the MODs section
Old 10-17-2007, 04:18 AM
svxual's Avatar
sorry 1000 opoligies
Old 10-17-2007, 04:53 AM
Nomake Wan's Avatar
Nomake Wan Nomake Wan is offline
Retired
Send a message via AIM to Nomake Wan Send a message via MSN to Nomake Wan Send a message via Yahoo to Nomake Wan Send a message via Skype™ to Nomake Wan
I knew a guy who was tinkering with the idea of putting a different supercharger on, but haven't heard anything about it as he is... incommunicado.
Old 10-17-2007, 05:32 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Painful... caps lock and punctuation are universally accepted as the common form to end a thought, before proceeding to the next. Please consider them.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 10-17-2007, 06:30 AM
Manarius's Avatar
Manarius Manarius is offline
Anything can be made to work. The question is: How much money do YOU want to spend on it?
-Jason
-Obi Wan Kenobi
Old 10-17-2007, 09:32 AM
They can be made to work OK, but nobody we know has ever done it. Your big problem is orientation and the fabrication that would be required to work them. [As in they were set up to feed an upright straight four, rather than a flat six] They could be made to work in the same way svxfiles mounted his. Check svxfiles locker for pictures.
To be honest, if you were going this route you would be far better off to fit a new Rotrex. They are not too cheap but are very compact and can give any power you want.
