Old 10-08-2007, 03:33 PM
kwren's Avatar
kwren kwren is offline
move to a different gear ratio. 4.11 and 4.44 gears
what does this mean? Are these gears actually in the transmission or where??
Thanks,
Keith
Old 10-08-2007, 03:42 PM
lazer lazer is offline
swapping the final gear ratio involves a change of differentials in both the transmission and the rear diff.
Old 10-08-2007, 03:48 PM
kwren's Avatar
thank you! Where can I get how 2 on this subject?
Is it available and how big a job is it does tranny have to be removed or is differential a part of the tranny that I can work on in the car?
any help appreciated.
Ty
Keith
Old 10-08-2007, 04:11 PM
It's Just Eric's Avatar
Missing in action
Genrally it's easier to just put in a donor transmission that already has that particular final drive ratio.As for the rear diff, you'll want the svx diff with the ring gear changed, as the svx has a limited slip diff and the donor differental likely wont
shoot a private message to svxfiles, he knows prettymuch everything to know about 4.11 and 4.44 swaps
R.I.P Cool Signature.
davew833 davew833 is offline
Tranny has to be removed to do anything with the gears in the front diff, since it's sandwiched between the engine and the "actual" transmission. Rear diff has to be removed to do anything with those gears, too.
davew833@yahoo.com
Former 6-time SVX owner
