Old 09-18-2007, 07:37 PM
nightrider nightrider is offline
will this tranny work in my car, i found another
http://cgi.ebay.com/ebaymotors/Subar...spagenameZWDVW
my car had been converted to a 02 wrx 5speed, that i blew up, will thiss one bolt right in, or be easily modified
Old 09-18-2007, 07:50 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
The trans should go in fine, but you'll need to match the rear diff.
Old 09-18-2007, 08:25 PM
What Dave said....
Old 09-18-2007, 08:35 PM
do you think if i match the rear diff it will be a better gear ratio? does anybody kno the gear ratio? it isnt possible that it matches already is it? as u probly gessed i didnt do the 5mt swap, i bought it that way
Old 09-18-2007, 08:44 PM
Hocrest's Avatar
The WRX uses a 3.545 rear, the same as the SVX.
The RS is not a 3.545, it's probably a 4.11?? You'll need to get a 4.11 (or whatever matches) rear out of a Legacy and swap your LSD into it. The info to swap the diff is either in the "how To's" or in a post somewhere?
Old 09-18-2007, 08:49 PM
when lookin at gear ratio specs is it the first gear ratio or the final ratio?
