engine reseal question
ok so i replaced the valve cover gaskets on my car a week or two ago along with a plethora of other gaskets and things and now it appear that the passenger side is leaking very fast, like there is a3-4 inch puddle of oil under my car when ever i park. i think i may have over torqued them, is there any easy way to fix this or do i have to pull the valve covers again...arg
1991 xt6 eg33? 1993 gc track car |
did you replace the washer seals as well??
Tom |
the valve cover bolts have a shank on them, they won't over compress the valve cover gaskets; over torqueing is just bad for the bolts/heads. Like Tom said, if you didn't change the gaskets on the bolts they are probably leaking for just that reason--the shank on the bolts won't let you tighten down on the already compressed gaskets, they have to be new.
If it's leaking that bad, one of the gasket may have become unseated during install.....might want to pull that side back off and check it. As for the bolt gromments, a cheap alternative is to install a 0-ring under each old one to seal them... See ya this weekend at the Dragon!
Jeff, also, they're the same round gasket that is on EJ engines, and I think the same as EA82's also??
