ECUtune SVX pistons
We've gotten in the first batch of custom SVX pistons so it's time to start this thread. This piston design is now established for us so we can offer them as individual sets. They will be made available on our website when I revise it for multitude of performance hardware options we are developing (pistons, cam sets, rods, transmissions, forced induction parts); except for the forced induction parts, the other performance parts allready have their own threads.
Price $1090 shipping $30 lead time 5 weeks highlights: compression ratio: 8.5 pins: tool steel valve reliefs: -0.275" anti detonation grooves Description: These are forged pistons designed for use with either gasoline or E85 and boost levels up to and in the 30's psi range. They are machined from the strongest forgings possible with emphasis being placed on strength. Appropriate rings are included and optimum ring placement for the application was incorporated into the design. Latteral gas porting was incorporated to facilitate sealing of extreme cyllinder pressures. Tool steel pins were used for maximum strength. Pins are centered as this is better for higher cyllinder pressures. Piston tops are designed for optimum squish area performance, intake charge mix, charge to spark kernel pressentation, flame propagation, and expansion force application. I'll follow this post with some pictures and some notes trying to illustrate the features. |
Stack of the 1st seven sets. These are all spoken for not stock.
![]() 1 boxed set open ![]() the boxes of rings and tool steel pins opened ![]() bottom/inside of piston note the holes that allow the oil from the oil control rings to pass through--obviously much stronger than the factory slots which were prone to failure. ![]() note the grooves for the Subaru Tru Arc pinston pin circlips note the the oil dispersion grooves on the pin oilers ![]() note the deep valve reliefs which maintain zero interference with high lift camsafts note the symetry of the piston top note the flat top matching the cyllinder head squish area ![]() note the anti detonation grooves note the deep ring placement note the latteral gas porting on the top compression ring ![]() |
Note the sheer awesome-ness of this thread...
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse ![]() -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ![]() -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ![]() SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
Do you know the weights of the pistons and the weight of the pins? are they lighter then stock? Cool but I'll have to wait for awhile on a set. Still machining deck insert to close the deck on my block.
Which box is mine, which box is mine??? Those are awesome. They can withstand up to 30psi you said, but what is the peak boost that we will safely be able to run on pump gas? I think you might have said what it was on the phone (15psi I think) but I am not sure.
BTW any news on the rods? You said that you were going to match the pistons and rods into sets before you shipped them to me right?
pistons are 419 grams. I think the pins are around 120 grams.
the forged piston complete with tool steel pin is about two ounces lighter than the factory piston and factory pin
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 04-23-2007 at 02:41 PM. |
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
![]() Hey, you must know some people who know some people to be even ABLE to get drunk in Quatar!! ![]() Joe ![]()
Diameter
Excellent specs. CP pistons are supposed to be top notch. Since this seems to be an obvious weak point from Tom's extensive experimentation, I think that this was a smart move. Can't wait to see them. Didn't you also mention that these were 97 mm diameter in a previous thread?
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
![]() ![]() ![]() Jay
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! Last edited by JaySVX; 04-24-2007 at 11:28 AM. |
![]() Tom |
I defidently want to check it out at some point what your doing with it. Sounds like it's defidently out on the verge of invention.
