Front end rattle???
Since I've been pushing the SVX a little harder during the warmer months while autocrossing I've been hearing an increasingly pronounced rattle from the front end. It became more pronounced after the installation of Koni inserts. At first, I traced it to athe front anti-sway bar end link being insufficiently torqued. Solved that but a similar noise persists. All strut mount fasteners are tightened completely and I'm wondering if it may be the upper strut mounts causing the noise. It is most noticeable on low amplitude, high frequency (think rippled pavement) than at any other time. The bearings seemed fine last AUgust when I installed the inserts but the noise has gotten worse. I have also verified caliper and caliper bracket torque values.
Any thoughts? Todd
Down to none |
What about the subframe bushings Todd?
They are supposed to be suspended using some elastoprene or other such silent bushes. If one wore thin and was rubbing metal, it would make a noise, might it not? Joe
can you move the sway bar links a little bit by hand? because that would point to the sway bar links
Todd,
The sway bar links have a way of working their way loose (okay, so maybe I put a little more force on them ) -Bill
You can take the sway bar links off and drive without them (just far enough to see if the rattle is gone).
I have the same problem after installing Koni's & stiffer springs. Koni has sent a warranty replacement set of inserts which I hope to swap out soon. |
Just had another thought.
Have you checked your steering rack? |
