Old 12-28-2006, 03:57 AM
mile-hi-bri mile-hi-bri is offline
Still another tranny problem/question
'92 w/about 75,000 miles on current tranny.
Good shifts in ALL gears, but slips ONLY in 4th gear and ONLY under moderate to strong acceleration.
Doesn't matter whether t/c is locked or not.
Adjusted trans band,(twice in life of trans so far), clean/fresh fluid and filters(aftermarket filter too).
Has Small Car shift kit too.
Does this sound like bad band or perhaps a solenoid, or, etc.
I thought 3/4 used same band/drum, so shouldn't it slip in BOTH 3 & 4?
Confused and frustrated and...?
Any ideas?
Happy Holidays to one and all!!!
Old 12-28-2006, 02:28 PM
oab_au oab_au is offline
Any ideas?
The high clutch is used in 3rd and 4th, the band is applied with the high clutch for 4th. So I would think the band is slipping. When it does, the box goes back to 3rd.
If the band is adjusted properly, I would check the line pressure to see if it is low.
One Arm Bloke.
Tell it like it is!
