Transmission Fuse
Hi all, hope you can help. My transmission is "catching" producing a bumpy grabing feeling when turning. The trans shop says the transmission is not damaged yet and when they reset the computer to test, the problem went away. My mechanic says it is a fuse but the SVX reference says the fuse is separate from the normal fuse boxes and is on the right side of the car. We can't find the fuse to replace. 92 SVX
Can someone please tell me where to find the fuse for the transmission? Last edited by jen; 11-16-2006 at 08:56 AM. Reason: add car year |
There is a FWD fuse under the hood. It almost sounds like the AWD is binding. By default the fuse is missing. If you insert the fuse you will force front wheel drive only and if your symptoms go away you've found the problem.
Sounds like binding to me.
The fuse is on the Driver's side engine compartment. If you insert a 5A fuse, it will disable the AWD and if the problem goes away, you have a very common problem. I drove around with the fuse in for about 30K before the tranny finally died, but officially, the fuse should only used for diagnostics and not for everyday driving. Doug
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
trans fuse confusion
Ok, as I understand the previous posts
1. the trans/awd fuse is located in the normal fuse box under the hood. correct? 2. there isn't supposed to be a fuse in the trans/awd place? If there is then it disables AWD? 3. What is the common problem (the computer signaling the grabbing)- how do I fix it, if it is not the missing fuse. Note the tranny was rebuilt about 5000 miles ago. Thank for your replys and patience, I'm jsut not sure how to proceed. The car worked fine when the computer was reset - at least on the way home. So how would I fix tourque bind. The tranny people said I needed to fix the underlying electrical problem that was messing up the normal computer function. My mechanic says it appears tobe a fuse problem. What is impending disaster? Last edited by jen; 11-16-2006 at 12:57 PM. Reason: question added |
Here is a good discussion about it: http://www.subaru-svx.net/forum/showthread.php?t=35657 Here is a great How-To: http://www.subaru-svx.net/forum/show...2&postcount=23 You will need to drop the exhaust, the driveshaft and the rear third of the transmission to get to the solenoid/transfer valve (all one unit) Its about a three hour job. Quote:
