Old 11-09-2006, 07:36 PM
dmnknightomega6 dmnknightomega6 is offline
HELP (exhaust I think)
All righty
My car starts with a raspy sound in the morning and starts to mellow a bit as the idle drops when it warms up.
When I accelerate. I have this loud noise as i step on the pedal. Actually it sounds like I have a custom exhaust setup with all straight pipes (like a straightpiped honda hatch). I can hear the noise from the front.
So, as I go toward high speeds, the noise does settles down at 60 as i hit the higher gears and stay at 2000 rpm.
The noise does create vibration as My steering column panels starts to make the plastic-vibra noise.
The tranny still rides smooth, i do suspect something fell from my exhaust (but i may be wrong) or is loose somewhere. No codes are being thrown.
Thanks
Old 11-09-2006, 08:58 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Put the car on ramps and visually check underneath. Check the Y-section, usually that's where the exhaust cracks. You can either see the crack by moving the cold pipes, or put you hand over the pipes without touching it to feel for a leak while the car is running. Good luck.
Old 11-10-2006, 07:34 AM
Hmm.....
Is this one of the few possible sounds. My fear is that it is anything else than the exhaust (like er... maybe tranny).
Is there a possibility its the manifold. /?\
Thanks
Old 11-10-2006, 08:55 AM
Speedklix's Avatar
Locker Link Solution
I had a leak at the egr pipe on my manifold once. I couldn't repair it so I got a used to replace, but it was caused by the pipe rusting out, not anything actually happening to the manifold. I think you'd have to really abuse the manifold to hurt em.
I've even drilled out the studs on my driver side one and put in new ones. I'm pretty sure I put them in a few turns tighter than it needed to be and still no issues.
I'd look at the donut gaskets in your exhaust, if a bolt rusts good enough the spring can break it off if you hit a good bump. It would make it loose enough for a good size leak and still look like it is together.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-10-2006, 12:31 PM
Er.... what are donut gaskets?
If you change your exhaust is there a gasket from the manifold that i have to replace?
Thanks
BTW the sound is a droning roar that gets louder as i step on the gas
Old 11-10-2006, 12:59 PM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
Thanks
A Donut gasket is a slang term for an exhaust flange gasket....Hope this helps!
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
