Old 07-25-2006, 08:26 PM
My92SVX's Avatar
My92SVX My92SVX is offline
My92SVX
Alcyone Silver Contributor
Question Glove box issue.. Help..
As mentioned in another thread. I just got my first SVX. I'm trying to figure out how to go about getting my glove box opened. It seems that the previous owner locked it. Now I can't open it. I would like to see if the manual is in there. I did manage to find 2 more ignition keys. Including the original grey unused key. However, they don't seem to open the glove box either. Any suggestions. Would I be able to call or go to the dealership and get the key for the glove box? Is there a seperate key? Or will I need a lock-smith? Help
Thanks again
Carlos
Old 07-25-2006, 09:18 PM
Manarius's Avatar
Manarius Manarius is offline
The lock might be broke. As far as I know, the ignition key opens the glove box.
-Jason
-Obi Wan Kenobi
Old 07-26-2006, 12:19 AM
The ignition key should work unless they had the car re-keyed. I would oil the lock and try it again. The valet key will not open the glove box, so I would suggest getting a new key that is made by the dealership by your VIN. This should be the proper key to open it. You could compare the key number on the key you have now with the one they look up. Good luck.
Old 07-26-2006, 02:37 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
It looks like a pretty simple lock. Have a go at picking it.
Google for "Lockpicking".
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 07-26-2006, 10:23 AM
Earthworm's Avatar
Meow!
Is it only the glove compartment you can't open?
Try the doors & trunk if you haven't already. If everything else matches then someone must have replaced the glove box door.
Old 07-26-2006, 11:19 AM
My92SVX's Avatar
My92SVX
Thanks to everyone that has responded to my thread. The car seems to be all original. I did use the key on the drivers door and trunk with no problem. I have noticed that a few things were kind of stuck from not being used. Like the sunroof didn't want to pop up and the auto window has to be pressed down hard for it to go down.. Maybe the glove box lock needs some wd40 sprayed into it.. Very carefully of course.. lol.. I will try the wd40 on Friday. Will give update.. Thanks again.
Old 07-31-2006, 06:22 AM
My92SVX's Avatar
My92SVX
Got it opened. Looks like there is something wrong with the lock assembly.
Thanks again for the advise..
Old 07-31-2006, 12:36 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
was there a chest of pirates gold inside? Or how about some rear wheel berrings, those are like gold.
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 08-01-2006, 05:27 AM
My92SVX's Avatar
My92SVX
I wish... haha.. Found the SVX binder with everything - minus the actual manual.. It even had the light pen.. lol... I went ahead and purchased a like new one from Ebay.. Just got it yesterday.. Very nice.. Oh.. And a few CD's..Looks like an older person owned my car.. Frank Sinatra and some swing s**t.. yuk.. Anyway.. Thanks for eveyones help.. Still looking at what to do with the trans..
Later..
